Where to get oil pump shaft coupler ?
precisionag
02-02-2008 18:09:17
I had a little moisture in the crankcase and frosen oil pump gears allowed the oil pump shaft coupling to break. Does anyone know the deere part number or tell me who on the web has them? Thanks
Chris
Anderson
02-04-2008 19:27:17
 Re: Where to get oil pump shaft coupler ? in reply to precisionag, 02-02-2008 18:09:17
If possible find an original style one. Those heavy duty ones that don't break are not exactly the best idea. They are meant to break for a reason, instead of damage to the oil pump the coupling breaks.
wijim
02-03-2008 11:41:34
I just got one from Riesterer $ schnell for 19.80. the heavy duty one they had it in stock
donwisc
02-03-2008 11:30:47
When I ordered one from Deere it was the heavy duty one. If you want this style go in your tool box or go to Ace and pick up a 1/2 in drive socket and modify it to suit. It will look just like what you get from deere.
Mrbilman
02-03-2008 11:03:35
Look in ebay. There are three listed at the present time. just do a search for john deere b oil pump.
Maark
02-03-2008 06:49:43
Just dig the broken 1 out of the bottom of the crankcase and weld it back together. I've done that many times. I don't care for that heavy duty coupler JD sells now.
NE IA
02-02-2008 22:21:57
I have made a few with I think 1" square tubing. It has been fifteen years since I made the last one, but I always wonder if I built them to strong in case somethig did go wrong. Since then I have got them from mom deere, a stock on shelf item a few years ago.
Mike M
02-03-2008 05:31:36
 Re: Where to get oil pump shaft coupler ? in reply to NE IA, 02-02-2008 22:21:57
Last I heard Deere changed theirs to a thicker one that is round on the outside. Likely will break a shaft or pump gears now ?
Andy Motteberg
02-02-2008 18:51:50
Try the Deere Dealer or the Classified Ads.
Johnschu
02-02-2008 18:21:56
I have a 39 B and bought a new coupler from deer a few years ago the part number for a B is B250R
Bob
02-03-2008 11:29:55
 $$$ in reply to Johnschu, 02-02-2008 18:21:56
WOW! I just punched that $ in JDPARTS... through the nearest dealer, it is $37.54!!!
