Bob � on the M tractor, I have the decal location instruction set finished. I tossed the hood decal instruction section out for critique, but lack of response indicates a bunch. Shoot me a short note to open the email channel and I will share the set with you � if you are ready. The total review process should wrap up soon and thereafter, these data will be posted on the JD-H Restoration Site (below). You are right � the parts catalog doesn�t provide historical data of any kind unless the data affects form, fit or function. All of those were rewritten and the 60�s unfolded and the effect was to wipe out all the history! Now, old operator�s manuals would be far more beneficial. Now, on the JD-H tractor, buying buckets of bolts and parts can be risky. Plus missing rears, both wheel and tires, gives you an immediate $1000 headache. The tractor may be better utilized as a parts tractor if the price is right! As for parts � replacements for most anything you will need are generally available in one form or another � again, not without cost. Hoods can be expensive � no known after-market source just yet, and when one does appear on-line, you will be looking at $800 to $1000. Reparable used ones can be had in the $300 - $600 range depending on how much repair is required. As with any JD model, you need to recall that tractor serial number is a very important part of the procurement process. If the H turns out to be a 39-H (H1000 � 9999), it will have lots & lots of peculiar parts. There is a special piece about the 39-H on the site below � scan across to SPECIAL INTEREST, and from the drop-downs, select 39-H. While there, you will see many H-related technical help pieces under the headings of ARTICLES 1 & 2. And there a very good technical data package waiting for you if the H is chosen as your group�s project. And the earlier you acquire the needed tractor manuals, the better prepared you will be when it comes to acquiring a specimen and (of course) getting started on it. (PatB)
