4430 Hydraulic Noise in Cab.
eamay
02-01-2008 18:34:49
I have a 4430 I bought last year. I have been hearing noise in the cab, and suspect hydraulic problem. When turning the steering wheel maximum either way it decreases greatly when turned fully.
When hitting the brakes there is also a change in the sound. occassionally brakes require pumping.
Is air lock possible or do I have some other more serious trouble. The bypass line going back into the tractor seems hot, and feel vibration.
I would certainly appreciate any input to solve problem. Thanks, Arnold
Lee B
02-02-2008 22:32:57
 Re: 4430 Hydraulic Noise in Cab. in reply to eamay, 02-01-2008 18:34:49
The neighbors 4630 had a small hose under the dash keep blowing apart and costing more in lost Hy-trans than ten of the cheap one ply hoses was worth. Each time it happens we ask the counter guys what to do and they keep recommending the $1000 steering box overhaul instead of 2 foot of hydraulic hose we finally settled for 5 years ago.
No more real problems, but now it when the engine is very quiet it sometimes sounds like a litter of kittens has been secreted away under the dash. There are no cats on that farm though so I know it's not really kittens at all. The brakes on that tractor used to grab and chatter like the back end was about to fall off of it when used hard while cold. Then we put in one five gallon bucket of universal hy-trans equivelent from NAPA and the God-awful chatter just went away. The only hydraulic "symptom" that we continue to have with that tractor is just after we start it up after a long time down, the three point chatters for some 30 seconds as apparently the air gets worked out of the hydraulic system. All this while the three point is trying to climb back up to the top position and can be seen to jerk in unison with the chatters of the hydraulic system. During the same period of time the brakes don't work and the front end bucket is worthless too. And at low engine speed sometimes the front end bucket is less than responsive and I seem to remember pumping the brakes at those times too.
In my opinon a $1000 steering box that still works is not "serious trouble" when $10 worth of steel backed hydraulic hose is a cheaper "fix". I know nothing has really been fixed here, but until the steering outright quits or she starts steering herself, we are done with that "problem".
You'll have to decide for yourself just how much you want to spend and how expensive some hydraulic noise is worth. By all means if MattD can lead you thru to a cheap fix then do it just like he says - we didn't even begin to find out our options past the $1000 steering box guesstimate.
mattd
02-01-2008 19:33:27
i think you found your cause. what line did you grab, the bleed line from steering or brakes. is your serial number after 27635. if it is then u have a steering metering pump instead of a steering valve type. if the line you grabbed is steering then the steering block is likely leaking. this is located under the hood. its got lines coming from the cab and to the steering motor. remove the screen and see if there is any metal particles. take the big plugs on the ends out and remove the valve, if there is any scratches in it then its shot. the valve and housing is a set and its like 800 bucks. it also could be the metering pump which is easy to rebuild and cheap. it takes less than 3 hours. if you have an early tractor then the steering valve probly needs rebuilt. much harder and takes longer. if you grabbed the brake bleed line then your brake valve needs rebuilt. is the line you grabbed plastic or rubber. where does it go. lets make sure you have the right line first. in any case the steering and brake bleed lines should just drip. nothing more. i think the spec is less than a quart at 1000 rpm in 1 minute.
