Crankcase ventilator pump and plumbing
Dave in SV
02-01-2008 16:48:48
'49A serial number 634007. Per the PC675 and JD-4 manual, a ventilator pump is located at the aft end of the fanshaft tube. The part number on my ventilator pump cover casting is B2652R, which has no provisions for attaching external tubing. The front end of the fanshaft tube has external tubing running up to the air intake, and there's another external tubing running between the rocker cover and the air intake (just before the carb).
Does the ventilator pump draw (or supply) air thru the fanshaft tube?
Is my tractor plumbed correctly?
What does a ventilator pump do?!?!?!?
Tom43
02-02-2008 06:45:01
 Re: Crankcase ventilator pump and plumbing in reply to Dave in SV, 02-01-2008 16:48:48
Dear Dave,
Very good question! The ventilation system has been changed several times. The tractors prior to the steel frame tractors had a serviceable breather system like an oil bath air cleaner. The early pressed steel frame tractors have a system which you describe with air being drawn down the fan shaft tube. This arrangement changed at #648000 with air being drawn from the intake elbow. At#692121 a different style pump was introduced. With the introduction of the 60 crank case air was expelled to the atmosphere from a tube in the valve cover. This arrangement continued through two-cylinder production.
