1949 A JD .045 Pistons
GeorgiaHayFarmer
02-01-2008 14:24:21
Howdy,
If anyone has a good usable set of .045 pistons for a 1949 A, let me know. I have posted an add in the classified section as well.
Thank you,
Scott
Matt L
02-02-2008 22:21:29
 Re: 1949 A JD .045 Pistons in reply to GeorgiaHayFarmer, 02-01-2008 14:24:21
So how do you balance a jd 2 cylinder?
Just the bare crank on the balancer or do you need the flywheel and all that?
GeorgiaHayFarmer
02-03-2008 06:31:25
 Re: 1949 A JD .045 Pistons in reply to Matt L, 02-02-2008 22:21:29
I suppose if one were to balance an engine, then you would have to match the weight of the pistons to the crankshaft and what ever was riding on the crankshaft of which there are a million and one ways to accomplish on any engine. Do most folks go to the trouble? I don't believe so. Does one need to? As stated in my other post, thats the sixty dollar question. I doubt it. What I meant by imbalance is a noticeable vibration after going from cast iron to aluminum. Will it hurt anything? We'll see in about 50 years or so.
Scott
The Dukester
02-03-2008 11:38:58
 Re: 1949 A JD .045 Pistons in reply to GeorgiaHayFarmer, 02-03-2008 06:31:25
I've got 'em, still on the rods which have decent spun in type bearings. There's no rings on the pistons which are John Deere cast ones-.045 overs when I needed the block...I removed them about 11 years ago from a parts tractor...a '48 AN. I've got the head too with the valves ground. Gimme a e-mail if you wanna get 'em. Only problem is I'm up here on the tundra in Southern Michigan so the transportation won't be [email protected].
jd b puller
02-02-2008 05:47:50
 Re: 1949 A JD .045 Pistons in reply to Kevin Schmidt, 02-01-2008 14:24:21
GeorgiaHayFarmer said: (quoted from post at 09:04:39 02/02/08) Thanks for the reply. I suppose I should have stated I'm looking for used set of .045 pistons, preferably cast iron, not aluminum. I see that lots of folks are selling them for around 350 or 400 dollars new. There is a significant weight difference between cast and aluminum and I would rather put in a piston of the weight that the tractor was designed around.
Scott
I can't think of a single good reason why you'd want a cast iron piston in there. Aluminum gives better heat transfer, weighs less, which puts less stress on your crankshaft, connecting rods, etc. Oh, and it makes an extra pony or two due to the reduction of reciprocating mass. If going used, make sure the pistons are "good" before you put them in as I've seen someone say he's seen broken top rings on 50 year old ones before.
Dave in SV
02-02-2008 07:01:39
 Re: 1949 A JD .045 Pistons in reply to jd b puller, 02-02-2008 05:47:50
If aluminum pistons are installed, do the counterweights of the crank need to be reduced? If the counterweights are not reduced, won't there be a lot of imbalance?
GeorgiaHayFarmer
02-02-2008 10:38:56
 Re: 1949 A JD .045 Pistons in reply to Dave in SV, 02-02-2008 07:01:39
Yes there is an amount of imbalance that is noticable. Does it hurt anything? There's the 60 dollar question. This is the reason I'd like to stay with the cast iron pistons. It's a personal preference more than anything else. Although having taken a few aluminum pistons out of tractors over the years I have seen enough damage to know that I prefer cast iron regardless of horsepower increase or decrease etc. I've got an A that has aluminum pistons in it. It runs great and probably yields more horsepower. After a half a days work in the field pulling disks or plows I don't much care about the difference between the two as far as horsepower is concerned.
Scott
Andy Motteberg
02-01-2008 19:26:35
Hi Scott,
YT sells new pistons or engine kits.
Andy.
GeorgiaHayFarmer
02-02-2008 05:04:39
 Re: 1949 A JD .045 Pistons in reply to Andy Motteberg, 02-01-2008 19:26:35
Scott
Andy Motteberg
02-02-2008 11:39:17
 Re: 1949 A JD .045 Pistons in reply to GeorgiaHayFarmer, 02-02-2008 05:04:39
If you want cast iron pistons, try the YT Classified Ads. I have a 1949 A too that I'm restoring and it has M&W .045 over Aluminum Add-Powr pistons. I weighed them and a cast iron piston is about 20 lbs, and a aluminum piston is about 7 lbs.
