Like others have said, 2ea 12V in parallel, with short 00 cables will definitely do it. It spins mine so good that I don't have to use a starting aid and I cranked the 4230 yesterday having been sitting for a month in this cold weather.....well cold for N. Texas (20F). I like to use 900/950 cca OTR truck batteries in size 31. Size 31 is like your 27 used for trolling motors on boats, but it has 2ea 3/8" studs rather than lead posts; much better connections that don't get crudded up like lead posts do. The trucking co. where I buy my batteries makes custom cables and the lugs go right on the battery and really makes a nice package. Other thing about 2 12v batteries wired in parallel is that rather than having all your starting current run through the resistance of two batteries, this way you have cut the resistance of one battery in half, so you have 1/4 the series resistance in the starting circuit, and if you don't think that matters..... ..... On the 4230 the size 31 drops right into the battery box and I have one on either side of the tractorin front of the cab. Was not a problem to route the new cables under the cab where the OEM cable ran. Ran both cables over to the left side battery and then installed short jumper wires from it to the starter frame bolt and the solenoid. On the 4010/4020's I had, I trashed out the OEM long skinny battery boxes and built a square box for both batteries to sit side by side and bolted it onto the frame adjacent to the starter. Max 00 cable length on this setup was 15" and if you don't that johnny didn't sing a melody..... ... This works great, batteries were less than $80 a year ago and you will be happy you spent the time doing it. Mark
