Engine valves, springs, and rotators for later A
Dave in SV
02-01-2008 05:36:38
I am gathering parts in anticipation of rebuilding the head on my '49 A. Are rotators advisable? If I am reading the PC675 correctly, spring part numbers are contingent on whether rotators are used or not... an option that appears to be available on my serial number 634007.
Also, since I have not yet removed the head, I have no clue what I might find... are there "typical" things that one can expect is in need of replacement? Or are there things that commonly go bad? I already have NOS guides and valves on hand.
4020LP
02-01-2008 08:30:15
 Re: Engine valves, springs, and rotators for later A in reply to Dave in SV, 02-01-2008 05:36:38
Valve rotators for two-cylinder tractors were not used until the LP-Gas tractors were introduced in 1953. If you want to use them in your "A" (not a bad idea if you're going to be working it hard on today's fuels), then use the valve springs and rotators from a Model "60" LP.
Dave in SV
02-02-2008 04:29:03
 Re: Engine valves, springs, and rotators for later A in reply to 4020LP, 02-01-2008 08:30:15
I do not plan on working the tractor very hard... hay rides, parades, country road cruises. Would rotators be a detriment in this case? Also, if I DO use rotators, the PC675 calls out springs and rotators for the A... are the parts for the 60LP better?
J Schwiebert
02-01-2008 07:03:59
The last few A heads I did while working in the machine shop I had to install valve seats in as stem height (valve recession) was way out to lunch and that also affects your installed spring height.
Dave in SV
02-01-2008 08:15:21
 Re: Engine valves, springs, and rotators for later A in reply to J Schwiebert, 02-01-2008 07:03:59
Were the seats originally part of the head casting? And if new seats are required, the head needs to be cut and new seats pressed in? I don't see seats in the PC675.
J Schwiebert
02-01-2008 18:04:46
 Re: Engine valves, springs, and rotators for later A in reply to Dave in SV, 02-01-2008 08:15:21
That is correct. A machine shop can counterbore the head and install the seats. Use alloy seats for the exhaust cast iron or alloy for the intake seats. Then check you spring installed height and cut the seat to match. If you need dimensions for seats I will look them up for you. Other questions? J.
Dave in SV
02-02-2008 04:25:26
 Re: Engine valves, springs, and rotators for later A in reply to J Schwiebert, 02-01-2008 18:04:46
Thanks for the info. When I get to the point of actually redoing the head, I'll probably have more questions. I'll contact you again then!
