2510 closed center tractor
Bill Wy
01-31-2008 20:05:30
Reading thru the john deere forum they were talking about adding a loader to a 2510 tractor. They said the tractor was a closed center tractor.
Can someone give me a description what they mean by a closed center tractor? Thanks Bill
jdemaris
02-01-2008 05:59:44
 Re: 2510 closed center tractor in reply to Bill Wy, 01-31-2008 20:05:30
To be technical, "closed center" means that the main hydraulic control valve actually has a closed-center. All flow of oil is blocked and cannot pass through it when it is in neutral position.
An "open center" system has a main control valve that is wide open when not being used - and oil flows through it all the time.
If you hook a "closed center" valve to an "open center" tractor - the hydraulic pump will blow to pieces as soon as you run it.
If you hook an "open center" valve to a closed center tractor - you will have no hydraulics.
Because of all this - many newer hydraulic control valves are convertible - and you can make them open-center or closed-center just by switching a plug.
Bob
01-31-2008 20:13:35
With a closed-center system, the hydraulic pump pressurizes the system to a specific pressure (deere typically 2250 PSI), then "goes out of stroke" enough to maintain that pressure, but no more. There is NO continuous flow of return oil to the reservoir. (Except for a little leakage.)
With an "open center system", there is NO pressure unless a function is being used, and a steady flow of pumped oil is continuously returned to the reservoir.
