Anyone measured manifold vacuum?
Duane Larson
01-31-2008 19:40:12
Has anyone measured manifold vacuum on any two cylinder Deere? Some manifolds had an intake tap to run a milking machine vacuum pump when the power was off - I'd like to know some values of the manifold vacuum if anyone has them. Trying to save myself some work.... Thanks!
Duane Larson
02-01-2008 18:46:12
 Re: Anyone measured manifold vacuum? in reply to Duane Larson, 01-31-2008 19:40:12
Thanks for your information - sounds like they generate plenty of vacuum.
jCarroll
02-01-2008 06:24:33
I made a fitting to go between the carb and the manifold for my model 40 beauties, so I could monitor vacuum as a diagnostic tool. I got similar readings to 4 or 6 cylinder engines. My memory has nothing filed under running very slow - whether the readings flucuate a lot. My slow idle is around 500 rpm, and hi is 1826.
Lee B
02-01-2008 01:53:47
I don't have any measured figures but I know it's severe. My 44 A doesn't have the fan powered vent pump and I wanted my crankcase ventilated very well so I set it up with an auto type PCV valve pulling out of the valve cover. The restrictor valve inside it slams home so hard the device jumps out of the tight grommet lined hole I cut for it so I had to add a bolted on fork like holder just to keep it in place. If you pull it out of the valve cover it sounds for all the world like a loose air hose gone amuck in the shop. Awesome.
My somewhat educated guess would be fully 25 inches at peak times during a 720 degree rotation of the flywheel. And that of course at idle. If you put your thumb over the PCV valve you can sure feel a hard vacuum trying to pull your thumb right on in there. But only in surges, plenty of volume though. One Deere should be able to take care of several cows.
My white oil problem has gone away where I had a severely cracked blocked which was repaired 5 times and yet cracked again. 5 big bottles of Bar's leak, a good breeze through the crankcase during several hard workouts and I have dark oil once again.
