Best radiator core?
dx29
01-31-2008 14:59:12
Who sells the best radiator cores for 2-cylider tractors? I have amodel 50 that need one. I looked at JD heritage.net and theirs seem good. I have a lot of stories of buying "cheap cores" that end up not being well made. I see them for $150 on ebay but who is to say that the more expensive ones aren't the cheaper quality?
Point me in the right direction!
jdbill
02-01-2008 13:26:32
 Re: Best radiator core? in reply to dx29, 01-31-2008 14:59:12
I'm actually going to be listing a new one tonight or tomorrow on this web site. I bought it to replace the one in my 50, and shortly afterwards, bought the entire cooling system off another one so I could get to a 'normal' thermostat system (which included a good radiator). It's still in the original box, just taking up space in my garage. If you have any interest, let me know.
Carl NY
02-01-2008 07:36:05
This site YT sells a good radiator. I have used the brand they sell as well as ones from A & I and they all perform OK.
Mel in SW Iowa
02-01-2008 06:40:57
In 2000, I purchased a new radiator core for my
720 gas from a local JD dealer for $140 or so. It also said made in Ireland, but bolted in and worked terrific so far. Good price and no regrets.
GeorgiaHayFarmer
02-01-2008 04:42:40
I asked a similar question to this a while ago and will post my experience here. I replaced a core in a 1948 A about 2 months ago. I got the core through Deere from A & I and found a "Made in Ireland" decal on it. Even though the amount of rows were more and size of tubes smaller than the core I replaced, I'm assuming the total volume of this core remained the same, if not more. I assembled the radiator with core and had no leaks. It is a very tedious process. I think I paid about 160 dollars for this particular core. When working the tractor the temp rises to where it should and stays there all day. So I am pleased with the results.
Scott
John Van Valkenburgh
01-31-2008 18:49:41
I can't remember exactly where I got the new core for my 50 but it was somewhere around $150 or so. I remember that it was made in Ireland of all places. Its held up well however and I don't have any complaints.
Good luck when you go to remove all the small bolts that hold things together. I did not have any problems with the large bolts breaking but the little ones snapped much easier. Would not hurt to soak them in penetrating oil for a few days.
Best of luck,
John
1953 Model 50
Jerry Pevehouse
01-31-2008 15:12:17
I have used cores from at least 3 or 4 different vendors in the past. I can't say that any one of them was better, or worse than the others. They all have seemed to work well and fit correctly. I don't have a copy of the green mag. with me right now, but by doing a google search I came up with SSB tractor parts wich showed one around $150. The unstyled replacement cores that I usually buy are $180 or so, from almost anyone. I haven't heard of any particular problems with any brand, sorry. Good luck, Jerry
