620 row crop
Animal
01-31-2008 14:28:45
I got this tractor to work on and it was a basket case, I have an IT manual and this helps but I need some other info. The steering shaft looks to be splined at the front bolster is that supposed to pull out of that collar? If so what keeps it in the colar when you are using it, also what is the extra fitting on the fuel tank, its a gas model, it looks like a smaller line hooks to it, if so where does it go? Thanx in advance on any and all help you can give me.
Rich Duane
01-31-2008 17:08:01
 Re: 620 row crop in reply to Animal, 01-31-2008 14:28:45
The small line off the fuel tank is the vent and overflow line. The line should end on the left lower side othe radiator.
Rich Duane
620
01-31-2008 16:42:25
it has a roll pin though the shaft to keep it in place .
Animal
01-31-2008 18:57:46
 Re: 620 row crop in reply to 620, 01-31-2008 16:42:25
Thanks a million fellas I really apreciate the info!
Mike M
02-01-2008 04:21:11
 Re: 620 row crop in reply to Animal, 01-31-2008 18:57:46
Once you put the roll pin in run a saftey wire through the hole and around and twist it on the outside bend it flat so it won't catch on anything.
