Diesel fuel usage question
tstex
01-31-2008 04:58:11
Hey Guys,
Hope you all are doing well...
With the high cost of fuels, wanted your opinion on fuel usage...have a 60HP 1996 diesel tractor w/ frt-end loader and i many times use it for 5-10 minutes, then need to take 5-10 minutes to work, then climb back on and use her again...this process many go on for 2-3 hrs when i am working by myself.
when diesel was cheap, i used to just let her run; now when i am not using her for short 5-10 minutes timeframes, i turn it off. Does the starting and turning off save fuel or does the starting of the tractor use a burst of fuel? I was also interested if there were any issues with the starter going this route? There have been no issues with the starter, but was just curious.
Anyway, the 51 JD MT is doing fine and taking my time at looking for a horizontal to restore.
Thanks for your opinions,
tstex
Texasmark
02-01-2008 06:44:14
 Re: Diesel fuel usage question in reply to tstex, 01-31-2008 04:58:11
Diesel (at least) Engines are rated for gallons/hr/hp. You could expect numbers like .1 for old ones where they weren't too concerned about economy, to .043 for my new tractor.
At idle in N you are only using enough hp to rotate the engine and the tranny input shaft.....not much.
On the wear to restart, you are wearing out your starter. I have the same problem when I clean out my lot and put dung into the dung slinger cart. I have to stop loading, drive out to the field, dump, and return. Leave it run or not? Haven't answered that question yet. Could go either way.
Nice thing about restarting is that it lights right off so there really isn't much strain on the starter.
Mark
Lee B
02-01-2008 02:16:18
Starting doesn't use any particular burst of fuel so it's more a balance between the hassle of doing it and wear on the starter which really isn't too much with a warm engine that starts easy.
I've heard of 5 minutes idling being the time limit for shutting it off, but it's really anybody's call. If it were me, I wouldn't have it running if I weren't working it, unless I just needed to get down to kick something around or cut the strings off of a bale for example. 2 or 3 minutes idling would be too much for my tastes.
jdemaris
01-31-2008 06:19:14
Starting doesn't take any extra fuel except in cold weather with a cold engine - and - diesels are pretty inefficient with the engine idling.
In regard to fuel costs - off-road diesel is still cheaper than regualar gas - just not as cheap as I'd like.
In regard to the starter - as long as it's using battery power to spin - and not to just sit there and make heat - you're not hurting it.
Mike M
01-31-2008 05:07:29
I think JD's operators manuals recommend to shut them off if idle for more than 5 min. or something like that. Your call really. If your engine is in good shape and regular oil changes you should have no trouble letting it idle. My uncle used to idle his for REAL long periods of time and had no engine problems and little to no starter and battery problems. He figured if he restarted them all the time his battery and starter costs would of been high. You just have to weight fuel costs verse starters,batteries, and down time. I doubt you will save enough fuel in 15 min. to to offset other costs even you you were idling a 4020 gas like Dad and I do.
