4320 seat suspension rebuild
Dean Barker
01-30-2008 20:03:21
It appears that the cast wheel that the flat coiled spring attaches to and the cable wraps around should turn on the shaft. Mine is frozen to the shaft; can't see how it would work that way, so I'm soaking it with diesel fuel to get it loose. Am I doing this right? Thanks.
Dean Barker
01-31-2008 20:39:08
 Re: 4320 seat suspension rebuild in reply to Dean Barker, 01-30-2008 20:03:21
Thanks for the tips, guys. I appreciate the information. I'll be very carefull not to put too much heat to the wheel.
ET
01-31-2008 11:48:38
It is very comon for that cable roller to be siezed to the shaft. If I remember right its made of aluminum so be carfull heating it. I always never-sieze the shaft where that rolled rides.
msb
01-30-2008 20:09:40
Take a large screwdriver, insert it in the slot and push in.You may have to tap on the screwdriver. Then you can turn the shaft.That is how the tension is set on the coil spring.Once you go back with it, tighten the spring as tight as you can get it with the screwdriver, with the seat in the fully raised position.
