rubber tractor lugs
Arnold Sharp
01-30-2008 19:14:44
Does any one know where I can buy rubber lugs to put on steel wheels?
easydoesit
01-31-2008 11:27:03
 Re: rubber tractor lugs in reply to Arnold Sharp, 01-30-2008 19:14:44
I have had rubber pads on GP flat steel which is ok(kind of hokey) but not the rubber lugs. Do the rubber lugs run good on pavement? Still clanky or rough? Anyone advise on these things? Easy
n29we
01-31-2008 16:00:34
 Re: rubber tractor lugs in reply to easydoesit, 01-31-2008 11:27:03
I put the TNT lugs on my Standard GP. Other than not digging up the pavement I did not feel any improvement in the ride. Still clunky. I took the lugs off and have been running the wheels without any lugs while I get cut-offs so that I can put tires on her. The TNT's were $750, so I agree with the other poster that I could have almost gotten wheels and tires for the cost of the Lugs. JimO
JRB
01-31-2008 14:44:15
I put them on my AOS. They ride better than lugs did (steel on pavement). They attach at an angle so you basically have rubber in contact with the ground at all times as the wheels rotate. Still a bit jarring though and they are kinda pricey. I think I coulda bought tires and tubes for what I spent on these!
Brian Bell
01-31-2008 10:06:14
Go to link below. Click on the rubber lugs link on the left side.
Arnold Sharp
01-30-2008 20:03:00
thanks Robert do you know if they have a website?
TomIN
01-31-2008 01:56:28
 Re: rubber tractor lugs in reply to Arnold Sharp, 01-30-2008 20:03:00
Link
robertl
01-30-2008 19:40:22
TNT Poly Div.
Taube Tool Corp.
1524 Chester Blvd Richmond IN 47374
1-765-962-7415
