syncro-range shifting
Bill Wy
01-30-2008 18:03:13
How are you suppose the use/shift a syncro-range tranmission? If I understand it correctly, you can shift on the go in gears in the same range without stopping and not using the clutch.. You are suppose to stop the tractor and use the clutch to shift to a gear in a different range. When using a loader and going back and forth into a pile of dirt is what I don't understand. Using the clutch,brakes foreward and reverse gears etc that you can and can not do. Thanks Bill
Bill Wy
01-31-2008 19:11:15
 Re: syncro-range shifting in reply to Bill Wy, 01-30-2008 18:03:13
Thanks for all the information. I was told the TOW had to do with 6/8 gear pos to remind you to always start in gear 6 than then shift to gear 8.
That was because starting in gear 8 is hard on the transmission. That could have been some costly misinformation. Thanks again, Bill
Gerald J.
02-01-2008 08:10:20
 Re: syncro-range shifting in reply to Bill Wy, 01-31-2008 19:11:15
TOW has to do with the fact that with the engine not running the top shaft isn't lubricated and if you tow in any other position on the shifter that top shaft will be spinning fast and will weld all the gears to the shaft from that lack of pumped lubrication.
It is nice with a heavy load of wagons on the hitch to start them in 6th gear, run it up to 12 mph, then back off on the foot throttle while clutching and shifting to 8th. The most I've ever weighed of the scale that was was 40,300 pounds with my 4020. I won't do that again, stopping is too hazardous if its not perfect. And I could only get 16 mph, not the 22 mph that I could with a lighter load. And its nice to be able to shift back to 6th to help slow down (but not so as to run the engine speed way up).
In the lower ranges there's hardly enough intertia, especially with an implement in the dirt to make shifting from 2 to 5 or 4 to 7 on the move effective.
Gerald J.
Indiana Boy
01-31-2008 19:06:11
Go to your JD dealer or look on EBAY to find an owners manual. This will go into the shifting and other operating functions in detail. The manual will pay for itself many times over.
Mike M
01-31-2008 04:43:30
Gerald is right on !
The forward and reverse gears in the right hand side of the quadrant have syncronizers so just push in the clutch and they should shift pretty easy. Going from forward to reverse I think it would be wise to let it slow down about all the way or else you could break something. The range shifts in the left hand side you NEED to be stopped to shift these.
Another IMPORTANT fact is if you need to tow one of these YOU NEED to put it in a special TOW position as marked on the lower left hand side. If you don't MAJOR damage will result.
Gerald J.
01-30-2008 19:09:46
Its Power Shift that needs no clutch.
Synchro range NEEDS the clutch for all shifts. Just the shifts on the right can be made while moving. The shifts on the left (ranges) need to be made sitting still.
Gerald J. Owner of 4020 SR.
6030MATT
01-30-2008 18:24:27
There are certain models that have and do NOT have the syncronizers for shifting from forward to reverse and reverse to forward without having to stop. As far as I know the 4000, and 4320 do not have these syncronizers, so you can not shift from froward to reverse or reverse to forward without stopping. Basically the reason was to save weight. But the 4020 3020 and 2520 did have the forward to reverse syncronizers. Now I am not familiar with the 10 series 4010 and so on. Hope this helps answer your question.
K.B.-826
01-31-2008 16:00:20
 Re: syncro-range shifting in reply to 6030MATT, 01-30-2008 18:24:27
Actually, all syncro-range and quad-range transmissions have forward syncronizers. Like you said, some of the later/bigger syncro-ranges, 4320 for sure, do not have the reverse syncro, and as far as I know none of the quads had it. So like you say, a forward to reverse shift on the move is not possible without grinding, but a reverse to forward shift would be. I think the reason for removing the reverse syncro was to make room for heavier-duty parts on that top shaft.
