K321S
arrious
01-30-2008 11:42:11
I hava a defective tripper switch on my kohler k321s and plan to convert the engine to a contact point set up--the hole that the point plunger goes through is blocked--does anyone know how to remove the blockage--is it a knock out plug, threaded plug or ??? thanks--Frank
ronco
01-30-2008 15:54:17
 Re: K321S in reply to arrious, 01-30-2008 11:42:11
Don't know what your K321 is powering. I did the change over in a JD 140 many years ago and I think I had to change ignition switches and also move a wire or two in the plug that goes to the ignition switch. Something you might want to check if your working on a 140.
Bob
01-30-2008 14:44:19
It is a small "cup plug".
Find a sheet metal screw the will insert into it and grab it, then pull and/or pry on the screw to pull the plug out.
woodbutcher
01-31-2008 04:43:46
 Re: K321S in reply to Bob, 01-30-2008 14:44:19
I have a K321S 12Hp on my Hobart welder. I'm wondering if I can change it over to electronic ignition. I don't want to have to ever set those points again.
Butch
Bob
01-31-2008 05:13:21
 Re: K321S in reply to woodbutcher, 01-31-2008 04:43:46
You CAN use an AFTERMARKET EI on your "points" engine.
HOWEVER, keeping the points allows the timing to be set precisely.
