1929 GP Oil Line Question
4020
01-29-2008 18:56:03
I am working on a 1929 GP. The pump to indicator pipe part number C629R does not have the soldered on ends like the other oil lines. It is just a long straight pipe with the flare nuts that had been wound full of string, so when they tightened it down it would seal up. I don't think this is right so I looked in the parts book and the pipe that is shows is just a straight pipe that has no ends on it. How are you supposed to seal the connections? Any help would be appreciated. Thanks, 4020.
coastiejim
01-31-2008 15:28:44
 Re: 1929 GP Oil Line Question in reply to 4020, 01-29-2008 18:56:03
4020,
I am currnetly working on the overhaul of my 1930 JD GP standard. I will check the line to the indicator and see how it is set-up.
Jim
d. coleman
01-29-2008 19:27:34
if the fitting the tube goes into has a tappered recess, then try to find a farrel and "B" nut. most hardware stores, auto supply, lowes, home depoe, ect. carry them in verious sizes to fit verious size tubing.
