3010 switch
jd4000
01-29-2008 18:45:01
3010 gas with split key and resistor on back of switch. Resistor "smokes" (gets hot) with key in RUN position. Tractor will start. Had just replaced switch because had to hold key in "correct" position to keep running. This happens on 2 switches I have tried. Did I get a wire switched around when I replaced switch first time? Wire are color coded but don"t have a color chart. Can anyone help with that(chart) or have any ideas?
Thanks
jd4000
01-30-2008 15:18:01
 Re: 3010 switch in reply to jd4000, 01-29-2008 18:45:01
How hot should it stay in the run position (too hot to touch the ceramic tube around the resistor)? A resistor will heat up, but that seems excessive without more protection.
Bob
01-30-2008 16:12:07
 Re: 3010 switch in reply to jd4000, 01-30-2008 15:18:01
Are you checking it while the engine is running or stopped, with the switch "ON"?
Switch "ON", engine stopped, points closed, resistor will get HOT HOT HOT!
With the engine running, the dwell angle (duty cycle of the points comes into play, reducing average primary current, and it SHOULD cool down some.
jd4000
01-30-2008 18:51:51
 Re: 3010 switch in reply to Bob, 01-30-2008 16:12:07
Checking now (since had a problem starting last week) with engine NOT running. Also, do have the electronic ignition. Sounds like I should start up & check then. May warm up enough to try this weekend - has been cold.
Thanks for help - maybe all is ok. Just had trouble starting a couple weeks ago. Had just changed switch because of original problem, and couldn't start after trying on a cold (-2) morning (had engine heater on for a couple hours beforehand). Had run it the nite before. Will start now. Will start & let run & see if still gets hot.
Thanks!
Bob
01-29-2008 19:34:51
A ballast resistor reduces voltage to the coil by converting excess current to heat.
They get hot. It's NORMAL. They smoke 'til stray oil from the manufacturing process (plus your fingers) burns off. That's the way it is!
What you need to do is check the voltage at the coil, with the engine running. IIRC, you should see about 9 Volts, give or take a little.
