Brake lining part numbers
Skyhawk Greg
01-29-2008 17:53:26
Hi,
Just picked up an early Model 70, and it seems to need a brake job. I might attempt buying some brake lining material and fabricating my own, but would like to compare prices on just buying them from a supplier. I have ordered a parts manual, but it has not arrived yet. In the meantime, I have turned up that the brake linings could be part number AA4253R, AR604R, or RE227939. Does anybody know if these are all the same thing? Is one a more flexible lining than the other?
Thank you,
Greg
Joe M(GA)
01-30-2008 14:40:55
 Re: Brake lining part numbers in reply to Skyhawk Greg, 01-29-2008 17:53:26
Part number AA4253R subs to RE235937
Part number AR604R subs to RE227939
The Original Catalog shows the AR604R for regular tractors & AA4253R for Hi-crops
third party image
third party image
Mike M
01-30-2008 06:16:12
Deere keeps playing around subbing numbers so likely you can only get one number. I'd call a Deere dealer and have them sub it to the latest number and give you a price.
Skyhawk Greg
01-30-2008 09:08:44
 Re: Brake lining part numbers in reply to Mike M, 01-30-2008 06:16:12
Mike - As you can probably tell, this post is a result of following your suggestion from the brake lining conversation of a few days back. In general, I'm one of those that prefers to find the P/N in a catalog first, and then, call the dealer. Since I usually order parts for older machines, many mistakes have been avoided by knowing what I want up front.
I'm going to be posting a generator question shortly, and hope you have some thoughts.
Thanks,
Greg
Mike M
01-30-2008 10:19:37
 Re: Brake lining part numbers in reply to Skyhawk Greg, 01-30-2008 09:08:44
Yep; I know all about the benifits of having your own parts books ! But JD and others changes numbers alot and it seems I can only get the latest and greatest info from a dealer. JD part.com doesn't seem to sub over my old numbers ? I am lucky to still have a good dealer that is just a toll free phone call away. My closest dealer is sometimes OK ? but they have higher turnover rate at the parts counter than the far away dealer I call who will do ( or knows how ? ) the extra searching
