HELP WITH 316 L +G
DOUG LEWIS
01-29-2008 17:28:48
HEY YOU HELPED ME WITH MY 49 B CHARGING SYSTEM LAST YEAR SO HOW ABOUT SOME HELP WITH MY 316. I HAVE A 316 WITH A B43E ENGINE. IT WILL ONLY RUN WITH THE CHOKE ABOUT 3/4 OF THE WAY OUT. THE SAME THING HAPPEN LAST YEAR AND A NEW FUEL FILTER FIXED THAT. HERE ARE THINGS I HAVE DONE OR TESTED. COMPRESSION IS 100 PSI. IS THAT GOOD? NEW FILTER.NEW PLUGS THE BOOK CALLS FOR NGKBPR5EFS WHICH IS NOW NGKTR5. I DO NOT SEE ANY LEAK IN THE INTAKE AND TRIED STARTING FLUID AND PROPANE AROUND THE INTAKE AND IT DID NOT RUN BETTER. THE FUEL PUMP WAS LEAKING ENGINE OIL OUT OF THE LITTLE PIN HOLE AT THE TOP.THAT CAN NOT BE GOOD CAN IT. IS THE FUEL PUMP WORKING TO HARD?
Bob
01-29-2008 19:37:40
 Re: HELP WITH 316 L +G in reply to DOUG LEWIS, 01-29-2008 17:28:48
1.) You need to thoroughly clean the carburetor. There are plugged jet(s) on the bottom half.
2.) The fuel pump is NOT leaking oil "because it's working too hard"! Either it is defective, or the crankcase pressure is too high, due to a clogged breather and/or excessive "blow-by", and oil vapor is beinbg forced out the pump's "weap hole"..
