JD 4255 MFWD
Dave Graeve
01-29-2008 14:54:35
I just got a 1989 JD 4255 MFWD I had it set up for 30" rows it only turns 25 degrees. What would be the best treadsetting for all around farm work. I know now that the later tractors tip the wheel as they turn so the tractor will turn shorter. after planting I will use my other 4255 2Whl for spraying. They show 8 different tread settings in my book, just want to know which one would be the best choice. Wider will turn sharper but How wide should I go? Dave
matthies
01-29-2008 18:47:27
 Re: JD 4255 MFWD in reply to Dave Graeve, 01-29-2008 14:54:35
We always set the front tires so they were the same outside width as the rears. Then set your stops like Kevin said, but then run one of your front tires turned all the way on a steep incline to have your axle stop first then turn to see if your tire/fender hits your frame rail. I always went over to the dock and had one wheel hang off the ground to make as close as the real world when you go through ditches and such. Never had any complaints just happy farmers who could turn short, sometimes they brought me other tractors to adjust. chris
Kevin Schmidt
01-29-2008 18:23:00
Should be a steering stop on both sides, it is adjustable a lot of diffrent ways by changing which bolt holes in the bracket and also by switching the bracket side to side. I always adjust them as tight as I can without rubbing the frame. After that you have to widen your tire stance.
PreciseFarms
01-29-2008 15:33:24
that tractor should have the tilted kingpin to make it lean in turns. Move the wheels to a good width to allow easy manuevering and tighter turning, say set up for 40" rows.
