420U brakes condition
bill420u
01-29-2008 14:06:58
The brakes on my 1956 420U do not work well even after adjusting them especially on the right side. I pulled the right side axle to examine them and discovered that they appeared to be in good shape though somewhat glassy and smooth. The tractor had sat for years.
I don't know what a new brake disc surface feels like. Is it possible that the asbestos plates need a little "roughing" up? If so, how does one do it?
Any other thoughts?
Thanks.
Mike M
01-30-2008 12:02:47
 Re: 420U brakes condition in reply to bill420u, 01-29-2008 14:06:58
Take any metal plate you can get out and sandblast the glazing off of them. Maybe take a scotchbrite wheel to the inside ones. Do you have oil free linings ? I used some new ones that were made grooved instead of smooth like my old ones were. Clean up the actuating balls and coat with neverseze when you go back together.
Fellow 420 owner
01-30-2008 10:03:46
If you have any leakage from the final drives, the oil can make the pads glaze over and become poor on stoppage power. If the seals have never been changed, I would start with that because new pads will quickly be the same way if it is leaking. Boy, are you in for a learning experience changing those seals. You may want to get a service manual. Both final drives will have to be removed from machine to effectively change seals. After all this the brake housings can be blasted to help roughen surfaces as well as the spreader inside. The trany case is the internal side of the brakes, so not much can be done there. Maybe use a needle scaler to roughen surface up a little. Good luck on your project, Jason.
CPeter
01-30-2008 06:18:44
I have a '56 420U and from what I have learned, the brakes never were very good. Mine probable could use new linings, but as you said, even adjusted up, they are only so-so at beast. Nature of the beast according to some. If you find some secret, we will both know.
CPeter
