4640 lube press
dwag
01-29-2008 10:33:45
Checking pressures after rebuilding C1,C2 clutch pack.C2 plates were warped. Lube press 50# with warm oil, should be 25#. Anyone else run into this? Book says possible blocked passage! Any help appreciated. John
rexhellwig
01-29-2008 12:57:12
 Re: 4640 lube press in reply to dwag, 01-29-2008 10:33:45
It would be pretty hard to choke off any oil passages doing a simple C1-C2-PTO pack repair.
{by the way, those seperator plates with notched tabs are supposed to be "warped"}
The lube test is very temperature and RPM specific, and is only to be checked at the port behind the right front cab mount. Make sure you are at 2000 rpm and your guage is good.
dwag
01-29-2008 17:20:22
 Re: 4640 lube press in reply to rexhellwig, 01-29-2008 12:57:12
Thanks. I was checking lube press off clutch/pto valve, will find, and plug into port you mentioned. The C2 plates I replaced were warpeddishedburnt badly.BTW New steel plates from Deere are all same, not dished, as numbers sub to same #, except PTO. Trans press was orig 150#, which could have caused failure. Thanks for your reply, John
