820 rear axle bearings
toolz
01-28-2008 21:07:46
I finally tore in to the old 820 I bought a while back. It has a bad outer axle bearing, so I removed the platform and rear housing to see the damage. I was surprised to find the bull gear in real good shape. The pinion drive gear has a few minor chips, but for what I'm using the tractor for, I don't see much of a problem. There is about .070-.080 side play in the differential, so I'll shim that. The axle looks OK, but I need the bearings and seals. Is Deere the best place to get the parts, or are there other sources? I've got all the part numbers- just need to know the best place to find the parts. Thanks- Kevin
David from Kansas
01-29-2008 14:40:34
 Re: 820 rear axle bearings in reply to toolz, 01-28-2008 21:07:46
Toolz,
If worse comes to worst, I've got some used ones just removed from an 820 that I would let go pretty cheap, just so someone could get some use out of them.
toolz
01-29-2008 15:19:10
 Re: 820 rear axle bearings in reply to David from Kansas, 01-29-2008 14:40:34
David- I sent you an email- Thanks
