70 Clutch Removal Questions
super99
01-28-2008 14:46:06
I am overhauling my 70 gas and am trying to get the clutch taken apart to check main bearings and replace the oil seals. I am down to the last clutch ring, and it is stuck on the 3 pins it rides on. I have been soaking it with PB Blaster everytime I walk by for about 3 weeks now and it still won't budge. Not enough room to get behind it with a small pry bar, so I heated a screwdriver and bent a 90 degree angle on the end to get behind the clutch ring, but still can't get it loose. Soaked it again. I hate to use heat inside there, but it's starting to look like that is going to be my only option. How do you guys get them off? Then I have to take the bolt out of the crankshaft and pull the round center out. Any tips on this? When I put it back together, what do you do to keep the clutch ring from sticking on the pins? The block and pistons are done and ready to go back in if I can ever get the clutch apart and it warms up a little bit. Anything else I need to do to the pulley while it's apart? Thanks in advance for any help you can give me. Chris
super99
01-29-2008 01:35:47
 Re: 70 Clutch Removal Questions in reply to super99, 01-28-2008 14:46:06
Thanks, I think it's going to warm up a little this weekend, I'll give it a try. Should I try to find a bolt that is threaded longer or can I just cut more threads on a grade 8 bolt and use that? Chris
F-I-T
01-29-2008 12:46:59
 Re: 70 Clutch Removal Questions in reply to super99, 01-29-2008 01:35:47
I just re-thread long Gr.8's to the depth that I need them. Just did that a couple of weekends ago because I couldn't find the pair that I keep as special tools.
F-I-T
01-28-2008 16:42:06
third party image
Sometimes you can take a piece of resin bond cloth, say 120 grit or so, and using a narrow band, maybe 1/2" wide x 12" long, and try to polish each pin until they will pass the bind. Once everything is out, you can polish them better, not until they are necessarily shiny, but at least smooth and clean enough to allow the plates to slide.
The "clutch driver", that cast iron plate in the center, is held tight by tapered splines on the crankshaft. Remove the cap screw and lock and flat washers. There should be two 1/2" threaded holes 180* across from one another. You install two bolts threaded high enough up to bottom out ans still have some threads left. I use gr.8's here so that they will not bend or deform. Then turn these tight, equal turns on each, until the driver pops loose. Before you hear all of the horror stories regarding how tough these can be to remove, I have to tell you that I must have led a charmed life, because I have never broken a good driver or had one refuse to budge using the bolts.
The backside of the pulley might benefit from some high temp grease on the touching ends of the dogs and toggles, re-pack the bearing, and inspect the toggle pivots for wear. You have to pull that big gear on the back to do this work, so some folks skip this task and just roll the dice that she will be all right. When in there, also inspect the operating sleeve sliding hole and pin for wear. If you find worn dogs, toggles, pivots, or sleeve hole and pin, it's another thread to talk your alternatives and appropriate repair.
HTH
Frank
super99
01-29-2008 01:40:39
 Re: 70 Clutch Removal Questions in reply to F-I-T, 01-28-2008 16:42:06
Another question. The big gear on the back of the pulley? Use a puller to get it off? Does it need to be pressed back on? Chris
Mike M
01-29-2008 05:31:39
 Re: 70 Clutch Removal Questions in reply to super99, 01-29-2008 01:40:39
Yes ,you do have to pull that gear off. They are TIGHT and I have a large 3 jaw puller that uses a hyd. port-a-power to power it and it works really well on those. I would suggest trying to rent a hyd. one to do it. You also need to find or make a heavy steel pilot for the center to push on. When going back together MAKE sure you support the inside of the pulley and DO NOT make contact with the fragile rim. I have everything setup and ready to go in my press then heat that gear to where spit sizzles on it then put it on. The last one I was lucky as when I laid the thick press plates on top of it to begin pressing it was hot enough it popped right down on from the weight of the plates. Otherwise I assist them with the press and make sure it is seated all the way on. I think most seat against a snap ring and also make sure you have the key in and aligned before you start.
