46 B and 49 B
dieselman
01-28-2008 11:06:21
well i want to take either my 46 b block and bore it to accept the 49 b pistons but those pistons are .090 over... will they fit??? or can i take a 49 block will it mate up with the 46 tractor and do i have to buy another head too???
jd b puller
01-28-2008 20:53:14
 Re: 46 B and 49 B in reply to dieselman, 01-28-2008 11:06:21
Diesel, what are you going to do with the 46? If it's just going to be a parade tractor, then you'll be able to swap the new block into the 46 tractor, no problem. You'll just be missing the bolts that go from the frame into the block. If you're going to work it at all, I wouldn't suggest it.
I'm with Mike, I don't think I'd put +0.090" from the late B in the 46 block.
I can get you +0.125s for the 46 if you want them. E-mail is open.
russ rolke
01-28-2008 20:41:40
i have a 43 b that we put standard 49 b pistons in with no problem it pulls great have had no problems at all for 3 years
jason r
01-28-2008 13:04:33
Your 46 block will not work and is not big enough to fit even standard late B pistons let alone .90. There is no way. there is not enough metal to do it. The oil passages and bolt patterns are different on the blocks too. I hate to say but your best bet is to get a good used block that is standard for your 46 and bore it to .45 over or take your block have it bored and sleeved to .45 or standard. You can't really go over that because the supply of .90 and .125 mid B pistons have dried up...I know I went to 15 suppliers to find them and they were all out. The company that makes them well..they don't.
Mike M
01-28-2008 11:16:27
those +.090 oversize late B pistons could be getting pretty big ? I have heard tell of past farmers using std. size late B ones with success so you really won't know until it is bored out ? they could hit a thin spot ? I have seen one of those B's with a late B block in it but it does take some noticable modifications.
Now the cyl. heads are all directly interchangable from 1941 up to the end of the B's you do have to watch out for one head casting number takes a different oil supply washer around the center stud than the other 2.
GeorgiaHayFarmer
01-28-2008 16:06:06
 Re: 46 B and 49 B in reply to Mike M, 01-28-2008 11:16:27
Mike,
I have the head that takes the different oil supply washer. Do you know where to get one as the one I have doesn"t fit correctly?
Scott
Mike M
01-29-2008 04:40:43
 Re: 46 B and 49 B in reply to GeorgiaHayFarmer, 01-28-2008 16:06:06
I can't remember if those washers are marked with a part number or not ? My first step would be to see if Deere or the dealer locator could come up with one ? Which one do you need ? If we can identify them maybe someone here has one laying around ?
