800 Series Mast Bracket
Skyhawk Greg
01-28-2008 09:59:50
Hello,
Having just acquired a Model 70 with an 800 series hitch, I now have a need for a mast bracket. After doing a little research, it appears that there are 17 different variations of this bracket that were available from Deere at one time or another. Here is a link from a website that someone really took some time to put together. It shows 15 of the mast bracket types.
Link
My question is, if you were only to get one of these, which one would you get, if you were going to use the hitch with modern day implements? Do you know the part number?
Thanks,
Greg
Skyhawk Greg
01-28-2008 10:45:05
 Re: 800 Series Mast Bracket in reply to Skyhawk Greg, 01-28-2008 09:59:50
Hi Mike,
Thanks for the thoughts. This seems like a completely practical, and inexpensive, way to go. Will probably end up doing this. In the meantime, I wouldn't mind finding at least one bracket, if for no other reason than authenticity. The anti-sway properties of your method may make it the only practical configuration in the end.
Thanks,
Greg
Mike M
01-28-2008 10:29:11
If I were going to use that hitch with modern day implements then I would not bother with any of them.
What I have done that works out really well is to get a piece of 3/4" rod or a bolt guessing 8" ? What you do is to remove the middle evener bar (missing on alot of them anyhow)from the adjustable rod ends. Now place one rod end on the OUTSIDE of the top link upright on your implement leave the space open in the middle where you normally hook a normal top link and then place your other rod end on the other OUTSIDE and stick this long rod through all of this and mark it to drill for cotter pins or something to hold it all sandwiched fairly tight together. What this does is also act as sway control since each arm goes off each side and the adjustable height works out pretty good for the tail of your implements.
Mowers, blades and booms have all worked fine this way for me. Now if you are going to use a mounted plow then you may want the original setup for a plow as they do need some sway to them.
jturbo10
01-28-2008 12:06:22
 Re: 800 Series Mast Bracket in reply to Mike M, 01-28-2008 10:29:11
I have a 56 JD50 with a 800 hitch. I have the evener and about three implements from the same era with the mast brackets. I have also used this hitch without the evener and just placed the two arms outside the toplink connection on the implement and ran a large bolt through the outer arm, implement connection, and other outer arm. You can then use the individual adjustment screws to adjust the implement. I used this arrangement on a finish mower, bushhog, 3-14 plow, and small 8 foot disk without any troubles. Good luck...I have found plenty of masts for sale on ebay that are like the first two displayed on the 15-17 picture on the link. Joe
Skyhawk Greg
03-07-2008 20:46:27
 Re: 800 Series Mast Bracket in reply to jturbo10, 01-28-2008 12:06:22
Thanks Joe for the thoughts. Tried it tonight, and it seems to work fine!
Greg
