How do I move the rim away from machine,
Kevin JD 60
01-27-2008 17:52:14
ok question, trying to move the rim away from the machine, widing the stance. I have loosen the three bolts on each side of the rim, jacked up the rear end. Turn the rachet bolt which sits opposite of the three, it does not move?
what am I doin wrong? it seems like the rachet bolt wont turn but does want to push in just an 1/4. either way nothing turns
Regan
01-27-2008 21:23:43
 Re: How do I move the rim away from machine, in reply to Kevin JD 60, 01-27-2008 17:52:14
Turn the wheel so that the grooves on the axle are at the 12 oclock position. Loosen off the three bolts on the outside of the wheel, then turn the two pusher bolts in clockwise to loosen the wedge from the axle. If the wheels havent been moved for a long time the wedge will likely be stuck. If so, use a length of pipe that will slide over the axle. Cut half of the pipe off creating about a one inch step so the only place the pipe will contact is the wedge that is to be loosened. Then slide the pipe over the axle and take a sledge hammer to the end of the pipe driveing the wedge in. Only when the wedge comes loose can you use the ratchet to move the wheels out. Hope this helps.
Dean Barker
01-28-2008 10:05:19
 Re: How do I move the rim away from machine, in reply to Regan, 01-27-2008 21:23:43
Excellent advice, Regan. In addition, tighten the pusher bolts, rap on the pipe and most likely the pusher bolts can now be tightened a little more. Now rap on the end of the pipe again and tighten the pusher bolts some more. Keep repeating the process until the wedge comes loose, then turn the pinion shaft to move the wheel. This process has never failed me on tractors that have not had the wheels moved for over 30 years. Sometimes the pinion has to be soaked with diesel fuel to loosen it up.
Dean Barker
01-28-2008 19:43:36
 Re: How do I move the rim away from machine, in reply to Dean Barker, 01-28-2008 10:05:19
Oh, and make sure your piece of tubing is longer than the axle. I then weld a one inch thick round plate on the end of the pipe to rap on.
Kevin JD 60
01-27-2008 21:55:26
hey guys thanks for the advice, will try tommorrow.
Regan,
those two pusher bolts you are talking about those are the ones between the three correct?
when I turn them clockwise , how far will they need to go? are they loosening or just breaking that wedge loose?
sorry for any confusion, if not I'll try the pipe trick..
how about the three bolts on the back of the rim (towards the machine)do thay play a role in moving the rim?
Regan
01-28-2008 06:23:07
 Re: How do I move the rim away from machine, in reply to Kevin JD 60, 01-27-2008 21:55:26
Yes, the two bolts between the three are the pusher bolts. Turn them in clockwise. They will come up tight because they are breaking the wedge loose. It will take a fair amount of force, but be careful not to break something. The three bolts behind don't have to be loosened. Good luck!
Kevin JD 60
01-28-2008 22:33:52
 Re: How do I move the rim away from machine, Now Brakes? in reply to Regan, 01-28-2008 06:23:07
Heys guys THANKS, worked like described
wedges were a little stuck but got them to move. Set them to fit my new fenders..perfect...ok can I ask you about my BRAKES...
I want to remove the drums and clean/check the springs and stuff. I have one pedal that sticks when I take pressure off. I have to reach down and pull back, maybe spring shot?
How do I get drums off. I loosened large nut and washer, now what.
Thanks
BushogPapa
01-27-2008 21:04:41
If the "Pinion" won't move, you can still move the wheel out by removing the wedge (held by the 3 big bolts.. BE CAREFUL...the tires could be filled with calcium and be darned Heavy..! With the wheel jacked up, and the wedge positioned on the bottom side of the axle, remove the wedge and (Have the brake set) turn the wheel on the axle until the pinion dis-locates and you can work the weel anywhere you want.. then let the pinion re-locate on the rack teeth and re-install the wedge.. This is really gonna take 2 people to make it a lot easier... Work Safely..!! Ron..
jdjack
01-27-2008 18:18:46
That wedge has to move in, to loosen on shaft.
Then i turn shaft so that slot in shaft are at 12 oclock with wheel just off ground and turn rachet it out.
jdjack
01-27-2008 18:18:35
jdjack
01-27-2008 18:18:34
jdjack
01-27-2008 18:20:49
 Re: How do I move the rim away from machine, in reply to jdjack, 01-27-2008 18:18:34
Sorry about all the posts
