1955 JD 50 rear rim width
dx29
01-27-2008 11:59:43
What is the rear rim width on a 1955 JD 50 with 38 inch wheels? I saw in an brochure that two tire widths were available (10-38 or 11-38 4ply). Is that on the same size rims? I assume that it is a 10 inch rim for both tire sizes?
dx29
01-27-2008 14:57:09
 Re: 1955 JD 50 rear rim width in reply to dx29, 01-27-2008 11:59:43
I found in an original brochure that there were two rim options. 9 inch and 10 inch.
Mine currently has 12.4 inch tires on it but I'm not sure of the rim width since it is measured inside lip to inside lip. Anybody have pictures of one with 11.2 tires on it? I'm just curious because I need to buy a new set when I'm done with the restoration. The 12.4s I have are mismatched and the 11.2 tires are quite a bit less expensive.
buickanddeere
01-27-2008 20:55:43
 Re: 1955 JD 50 rear rim width in reply to dx29, 01-27-2008 14:57:09
Mounting 11.2X38's on a 50/520/530 makes them look awful low, squatty and short on the back end. Your tractor will always be driving uphill. Even the 12.4X38 barely level the tractor with the factory original 6.50-16's on the front.
55 50
01-27-2008 20:05:09
I measured my model 50 rims when I had the wheels and tires apart for cleaning and painting. They are 11.25 inches across the far edges of the rim and 10.25 inches to the corner where the tire bead sets against. I have 12.4-38 Firestone Field and Road tires and like the looks of those quite well. Since the old size 11-38 (now 12.4-38) was "sort of" the standard when these tractors were new, I like to see 12.4-38s on them. I have several pictures of them but am no good at posting pictures on here !! But several years ago, I did post one photo from my work computer and placed it in Tractor Photos link at the left. Search for a 1955 John Deere 50 (with I think a "Ron in MN" identifier) and that will give you an idea of how they look.
Duane Larson
01-27-2008 14:24:54
dx29,
A Goodyear tire manual from Aug 1954 shows a 10-38 tire (now labeled 11.2-38) had a 9W-38 recommended rim, with 8W-38 and 10W-38 listed as "permissible". A 11-38 tire (now labeled 12.4-38) had a 10W-38 recommended rim, with 9W or 11W-38 rims listed as "permissible".
Later manuals tend to recommend the same rim size as tire size, eg 10-38 would take a 10W-38 rim.
bill mart
01-27-2008 13:50:59
parts book shows different rims for ten and eleven inch tires
