2950 hyd died what to do?
buford
01-27-2008 11:20:21
2950 w/ koyker k5 loader moving round bales hay worked real good sat a bale down all hyd died loader had worked fine for several months have pressure at rear 1600 psi 3 pt. works some times but not all times loader will not raise tractor will steer some but not good. where is the trans. pump filter? does it have a inline filter? on supply line? any help will be appreciated thanks to all Buford
buickanddeere
01-28-2008 10:41:06
 Re: 2950 hyd died what to do? in reply to buford, 01-27-2008 11:20:21
When the engine is running. Is there any howling, hissing or moaning hydraulic sounds from around the tractor or loader valves?
low budget
01-27-2008 14:47:04
Filter is in a canister under the right hand floorboard. Also a screen at the bottom of the transmission case , goes in from the side through a plug. (drain the fluid before removing and cleaning the screen) A plugged filter or screen can cause low output from the trans pump and starve the main pump, causing the symptoms you describe. Often the cause of the screen plugging is disintregrating brakes, (not good news). Another possible cause of low trans pump output is leakage from a line inside the trans, (blown O-ring,etc.)
WTW
01-27-2008 11:44:05
You should be seeing 2200-2250 psi out the rear outlets. If you have 1600 psi the steering still should be working. What is happening is main hydraulic pump pressure is low causing pressure control valve (priority) to protect steering by shutting off all hydraulics but steering. Replace and adjust stroke control valve in main hydraulic pump to get 2250 PSI at rear outlets and your problem should be fixed. Good Luck, DW
