JD 520 Powr Trol Lift Weight capacity
Tbolt76
01-27-2008 09:00:41
Does anyone out there know how much weight the powr trol lift on a 1958 520 can handle. I have to decide between two flail mowers to buy and the difference between the two is 300lbs. The heavier one weighs over 900lbs. Thanks.
LittleD
01-27-2008 18:41:52
 Re: JD 520 Powr Trol Lift Weight capacity in reply to Tbolt76, 01-27-2008 09:00:41
I have this on the back of my 1958 520 and it picks it up with no problem..... ...I do need the 4 piece weight set on the front to keep it stable.
Rich
third party image
Tbolt76
03-01-2008 18:53:38
 Re: JD 520 Powr Trol Lift Weight capacity in reply to LittleD, 01-27-2008 18:41:52
Rich, Have you ever used that plow, or know anyone who has used one like it? Tom
Jason Z in MO
01-27-2008 21:08:54
Rich,
I'm jealous! Wish mine looked like that!!! On the other hand, if it did I would never use it!
fixerupper
01-27-2008 15:16:43
We used to lift 2000 lb bales with a 630. The relief squealed some and we had a loader on the front so the front was never light. I don't know if a 520 has the same lift capacity as a 630 or not, but 900 pounds shouldn't be a problem. Jim
Mike M
01-27-2008 14:13:30
I ran an older 7 1/2' wide Blue Ford flail mower behind our 530 and it handled it fine and no extra frt. weight needed. I don't think I would go any wider or you will run out of HP for heavy stuff.
Jason Z in MO
01-27-2008 09:48:04
The 3pt on my 520 will pick up a 700-900 lb round bales with no problem. Will probably need some front ballast. Probably be fine if you have wide front.
I'm not familiar with flail mowers, what are the HP recommendations from them mower? Would assume the heavier one has a bigger cut requiring more HP. For myself, I wouldn't want to run the guts out of my 50 year old 520 by running at rated HP all day.
Jason
Tbolt76
01-27-2008 10:17:08
 Re: JD 520 Powr Trol Lift Weight capacity in reply to Jason Z in MO, 01-27-2008 09:48:04
Jason, The 2 flail mowers are the same size cut, just one brand is beefier than the other. Also, the heavier mower is rated for 35-60 HP tractors, the other one is for 30-60 HP. I'm thinking the biggest difference is the in the amount of steel and the ability to handle woodier material. I'm going to be using mine to cut warm and cool season cover crops which will be tall but mostly succulent.
buickanddeere
01-28-2008 10:42:24
 Re: JD 520 Powr Trol Lift Weight capacity in reply to Tbolt76, 01-27-2008 10:17:08
Go with the thicker, beefier mower.
