3010 hydraulic conversion kits
Regan
01-27-2008 08:39:36
I wanted to change the spools in the remote block from JD to Pioneer. I got the kits from the dealer for a 3020 thinking that they would work. Not so. The 3010 has a different set up. It has two "spool blocks" bolted under a flat mounting plate. I need a remote block for a 3020 or a 4020. What I was wondering is, does the 5020 use the same block? If it is I think I know where I can get one.
HeyPigFarmer
01-28-2008 05:37:18
 Re: 3010 hydraulic conversion kits in reply to Regan, 01-27-2008 08:39:36
For questions like that I go to jdparts dot com and look them up and compare part numbers. One of the handiest things on the internet right there. That way you aren't relying on word of mouth you get it straight from the source.
Gerald J.
01-27-2008 09:12:55
There were two different '20 setups not interchangeable. Both different from the '10.
I've looked at replacing the whole block on my early 4020 with the double pioneer connect under pressure block but haven't worked it hard enough to need it.
Gerald J.
