Greg: I'd have to dig through my old note books to find what I last bought. Not sure when I'll find that as I am heading out on the road again tomorrow at 6 am. To attach them, I like to rivet and use an adhesive. I grit blast the shoes on the mating surface, then I use a fresh bottle of urethane glue. I made some forms out of wood and my router and lathe, and fit the pad in, then the shoe with some glue (use wax paper to protect the mold), then clamp it in place. Let cure overnight, trim off any squeeze out foam, then rivet for added security. I have good luck with this method, and if you buy slightly oversized width and length pad material, if the shoe material slips a bit in the form, you can trim it easily after the glue is cured. The shoe holes provide guides to drill through for the rivets. Chamfer a countersink for the rivet heads on the top side, then set your rivets. If you have a shop press, you can use that to push the shoe against the material and it will mold and form nice and tight. Wood clamps work as well, but you need quite a few. Takes a day per shoe with the tooling I built. But whats time anyway. You can also use the drum as a form if you can rig the clamping to suit you, but the wood forms worked well for me. I'll try to find the stuff that I bought from McMaster-Carr, but the thickess you buy depends on the size of the drum you have, based on wear. Once I even set up a pivot jig to rub the shoes against my 14" plate/disk sander so that I could radius them for a perfect fit. It can take some time but the custom-sized shoes really last a long time. I have also re-laminated the two-sided clutch disks back onto the plate after the commerical adhesive had failed, and then drill and rivet as per the original. I just took an old set out that had run me for 6 years and they still looked great. A little thinner, so I put them on the shelf as spares during my recent clutch rebuild activity. HTH Frank
