850 jd
deene
01-26-2008 20:21:00
went and looked at an 850 today and it ran nice and was reasonably priced..didnt seem to have live pto is this true of it and the 950?..also need to buy a mower deck for it and found a 60 in but it has the pto shaft drive on it to hook to the aux pto off of the trans...is there a 2 groove pully to put on it as the 850 comes with a gearbox that attaches to the rear pto and is 90 degrees and has the large v belt pully on it to drive a mower deck..thanks for the help and advice
jturbo10
01-27-2008 19:40:29
 Re: 850 jd in reply to deene, 01-26-2008 20:21:00
I have a late 80s JD 850 with the two stage clutch. Works just fine with a finishing mower or bushhog. I"ve never had any issues with my 850 but numerous 850 owners have warned me to treat the clutch tenderly as they are not bullet proof and relatively expensive to replace. My neighbor also has an 850 and we used them two at a time to mow our grass runway. Very thrifty on diesel and doesn"t use a drop of oil between changes. Not a powerhouse so if you cut heavy grass you might want to consider a JD 950/1050 which I believe have turbo"s. I wouldn"t consider selling my JD 850 with the price of diesel...it just sips it even under a good load.
deene
01-27-2008 18:42:17
thanks for all the help and advice guys
Dan in Houston
01-27-2008 06:20:57
There are two models of the 850, those below serial number 16000 and 16001 and above. I have the first model, and it only has a single stage clutch. I'm not sure what all of the differences are, but I believe that the later models have a 2 stage clutch.
I wish mine had a two stage clutch, although it hasn't really been a problem. I spent all day last Sunday cutting the pasture with a 5' brush hog type cutter, full throttle, and it only uses a little over a gallon of fuel an hour. The tractor is a 1980 model and I've had it for almost 10 years. The only repairs I've had to make are new water pump, hoses & belts, new alternator, and new battery. It's been a great tractor.
machinery-man
01-27-2008 06:02:42
The 850 is based on tractor design rather than mower design. The combo type tractor755/855 ie had the twin ptos. Having said this a lot of the tractor designs came out with live power take off on some of the series.
Tx Jim
01-27-2008 05:00:18
 Re: 850 jd in reply to Hap, 01-26-2008 20:21:00
Rob I thought early model 850/950's had an internal over-running clutch istead of dual-stage pto clutch but I could be mistaken. Jim
RobMD
01-26-2008 21:25:27
The auxilary PTO shaft is only for tractors with mid-pto drive only. THe 850 and 950 never had this.
You can get a woods L59 mower, which is a good mower for the price. This consists of one large belt routed directly to the rear PTO shaft using a 14 inch pulley. I personally don't like the big JD-made gearbox contraption thing hanging off the back, but that's up to you.
Both tractors have Live PTO, in the form of a two-stage clutch. Push in halfway, the tractor stops. Push in all the way down, the PTO stops.
