60 cylinder head
HaroldJD60
01-26-2008 16:12:42
Hi, I took a 60 cylinder head to a city machine shop to have the valves done and have a broken manifold bolt removed. the tractor runs fine but if it sits for a few days it will only start and run on one cylinder. I have found that there is coolant getting into the combustion chamber. I had put in a new head gasket and the head was planed an checked for cracks. I have a hunch that the machine shop , when drilling the bolt out drilled into the water jacket. What do you gents think? If this is true can this be repaired. Thanks much, ----- --Harold
buickanddeere
01-28-2008 10:49:36
 Re: 60 cylinder head in reply to HaroldJD60, 01-26-2008 16:12:42
The nuts and studs have to be in prime condition without tired, pulled or worn threads. A hardened washer between the cylinder head and nut can reduce friction making even torquing more likely. Torquing in 5 or 10 lb steps instead of going from 0lb ft directly to 175 or 208 lb ft (can't recall) evens the clamping force out across the gasket. Any bolt or stud threaded into a water jacket should be coated with sealer.I was never lucky enough to get them to seal without.
BushogPapa
01-26-2008 18:24:21
I wouldn't give up all hope until you have gotten it FULLY Heated up several times, and while at full operating temperature, re-torqued the head bolts... The engine has to heated up long enough to Saturate it with heat...like an hour or so of use. Sometimes these sea[ for a while, until the gasted settles down, too.. Did you use any gasket sealer around the coolant passages..? Ron.
Mike M
01-26-2008 17:21:00
They may not of gotten that head flat ? I had one done once and double checked it and it came back worse than it left. I don't think their machines were big enough to do it right.
Those 60 blocks can crack around on the insides more on the top area and about 1 or 1 1/2" ? back. So look closely.
Drew
01-26-2008 16:45:26
Even if the shop did drill the manifold stud hole into water, I dont see how that could leak water into the combustion chamber and make it run on one cylinder. It could possibly seep a small amount around the stud threads, but I would think the manifold gasket would keep any water out of the runners and therefore the cylinders. I have purposfully drilled into water to fix manifold holes before and havent had any problems(dont remember if there is sealer on the bolts or not).
If the head truly isnt cracked, the next place I would look is the block. Is the deck flat and is it crack free?
