BEST PLOW to BUY
Tom 43
01-25-2008 15:39:57
I would like to buy a semi-mounted 5-18 plow with category 3 hitch. What are the pro and cons of various brands?
Handsome Jim
01-27-2008 14:12:52
 Re: BEST PLOW to BUY in reply to Tom 43, 01-25-2008 15:39:57
The last moldboard plow setup that Dad had was 5-18s on a White semi mounted. We used it behind a 5020 and later a 4620. Dad was always a die hard JD man but in later years, he came to prefer the Oliver and White plows. We didn't use it but maybe 6 or 7 years when everybody in our neighborhood got away from moldboard plows and went to chisel and V-ripper plows. The only mold board plows you see now days are the ones behind utility tractors plowing gardens in the fall.HJ
NW MO Poppers
01-26-2008 13:39:17
As with Scott in WI, I'm a Deere man thru and thru, but the easiest plow I've ever pulled was actually an Oliver, which became the White plow line. However, it wasn't built as heavy as our Deere plows, and that caused us trouble in it's later years. The Deere plows do a fantastic job in my mind, but the Oliver pulled easier. My 2 cents.
Scott in WI
01-25-2008 16:21:12
well I think u r opening up a can of worms here but I will give you MY opinion. First let me state I am a John Deere guy through out. I have owned a John Deere 4-18 2800 plow, IH 720 and 735 6-18 onland plows and various White plows including a 5-18. If I had to rate them the 720 and 735 plows pull the easiest and do the smoothest job. The JD 2800 plow I had was also an excellent plow and would not regret having another one. I would tend to stay away from the white plows as they pulled very hard for me.
jd40an
01-26-2008 10:57:25
 Re: BEST PLOW to BUY in reply to Scott in WI, 01-25-2008 16:21:12
My experience with how hard plows pull is EXACTLY opposite from yours! The hardest pulling plow I ever hooked to, considering the width of cut, was an IH 720 4-18 auto reset. This plow pulled unbelievably hard & did a very poor job of turning the soil, so much so we dubbed it our "Red rooter"! Never owned a JD 18" plow, but one neighbor tried to pull an, I believe 2800 4-18 with his 4020 & never got out of 3rd gear with it. On the other hand, we had a White 6-20 auto reset & it pulled very little harder than the IH 4-18 POS & turned the soil almost TOO well, as very little trash was left on top, in fall plowed corn stalks, allowing excessive wind erosion over the winter. The White plow, however, wasn't built as heavily as either our JD F145 4-16 or the IH 720. We used these plows in heavy, Iowa, Clarion Webster silt loam soils, which pull quite hard.
Handsome Jim
01-27-2008 14:19:46
 Re: BEST PLOW to BUY in reply to jd40an, 01-26-2008 10:57:25
In our dirt, pulling hard or easy wasn't the question. In that black gumbo, everthing pulled hard. We had better luck with clearance with the White plows when we were plowing corn ground.
Scott in WI
01-26-2008 20:24:44
Well like I said it is opening a can of worms. When I was in high school in the mid 1970's, the farmer I worked for had 2 Oliver plows. 1 6-18, and 1 5-18, both hydraulic reset and onland hitches, pulled by 150 hp tractors. I can't tell how many times we broke the furrow wheel and trail wheel on those plows. Came to a point where we would try only to turn to the right as turning left, if not careful would break off the trail wheel. When they got a new IH 735 adjustable width 6 bottom it was night and day difference. As I started farming on my own I bought a White 588 4-20 for my 4320. I would pull that plow in 3rd and 4th gear. However in 4th I had to watch the temperature as that plow really made the 4320 work. With the JD 2800 4 bottom adjustable width plow that I replaced the White with, I could pull that a gear faster. The 2800 was a nice plow. As my farm got larger I wss pulling a IH 720 6-18 with a 180 HP tractor. I NEVER and repeat NEVER had any issues with that plow. It did a real nice job. Used it for many years before going to chiseling my corn stalks. And the farmer who bought it from me is still using it. Just my experience
