JD 4430 Quad - trans chatter
Claysred
01-25-2008 07:41:03
I have a 4430 with a quad range that make a transmission chatter under my feet. It mainly does this when the tractor is warm. Any ideas what could cause this?
Other symptoms are the 3 point lift chatters and shakes when the tractor is first started. The 3 point will not go back down once raised unless you turn the tractor off.
powertech84
01-25-2008 16:15:49
 Re: JD 4430 Quad - trans chatter in reply to Claysred, 01-25-2008 07:41:03
could be load depth out of adjustment to loose. worth a shot before tearing of the valve.move the selector lever from d to l and back and see if it makes a difference.
MSM
01-25-2008 16:10:38
You probably have a bad leak in the rockshaft valving. The noise you are hearing is most likely the hydraulic lines vibrating under the cab which is caused by the hydraulic pump cavitating, which gets worse as the hydraulic oil heats up.
