How much will a John Deere Model 45 loader pick up?
ncpapaul
01-24-2008 16:38:10
How much will a JD Model 45 pickup? and how high? Thanks , Paul
buickanddeere
01-25-2008 16:35:02
 Re: How much will a John Deere Model 45 loader pick up? in reply to ncpapaul, 01-24-2008 16:38:10
Lets see,finding out how heavy a load you can suspend and drive with using a loader with 47+ years of "experience". That's looking for trouble.
ncpapaul
01-25-2008 15:01:40
Thanks to all who answered. I am trying to locate one in Mississippi to put on my JD 60. Just to move other 2 Cyl. parts and tires around the place and maybe help with a hay bale or two. Maybe trim a limb up high. The only ones I see are way far off so I will just keep looking, thanks, Paul
gitrib
01-25-2008 12:16:01
Nov-Dec issue of TWO CYLINDER carried info on 45 Loader. Could lift one ton of manure 10 1/2 feet.
Once mounted it could be stored on to stand and remounted in five minutes. They were built for tricycle Tractors. We have one BE CARFUL they call this a suicide rig.They can flip over real easy gitrib
jd40an
01-25-2008 09:16:48
I don't know how much a JD 444 corn head weighs, but I picked one up off a gooseneck trailer with my '52 B with the "live" pump behind the dist.I just hooked the front edge of the snow bucket under the back of the head & chained the top rail back to the front crosspiece of the loader frame.This placed the head VERY far ahead of the tractor, but it DID lift it! The front wheels were completely flat & the rears were barely touching the ground. Of course I couldn't move, so I pulled the trailer from under the head & set it down very slowly & carefully!
55 50
01-24-2008 20:25:25
the loader book says 2100 lbs
Dal in MO
01-24-2008 19:48:53
I have picked up and moved a brigeport mill with a 620 JD with a 45 loader, about 2100 lbs, was a little sceary. The front tires where almost flat and when real slow.
gold-leaf-deere
01-24-2008 19:20:15
I have a 45 loader on a 620, also there is a gin pole which extends about 2 feet in front of the forks. Recently I had a Big scale attached to the gin pole end, at the bottom of the scales I had a heavy weight. The 620-45 combo registered 1200 pounds on the scale. Also I picked up the rear of a 1955 I H C truck with the truck's frame rail ends even with the rear of the bucket.In my opinion, if you lifted from the cross pipe at the rear of the bucket, it would probably lift 2000 pounds.
4020LP
01-25-2008 03:42:14
 Re: How much will a John Deere Model 45 loader pick up? in reply to gold-leaf-deere, 01-24-2008 19:20:15
I'd agree with Gold Leaf. A ton or a little more or less, depends where the pickup point is. You'll never tear one up with the hydraulic pressures available to you with a two-cylinder tractor. Onee of the best inexpensive loaders ever built, and would take abuse far beyond what it's designers ever intended, I'm sure.
johndeereman
01-24-2008 16:41:22
this really depends on the tractor hydraullics unless you are asking how much till the frame breaks which depends on the condition of the tubes
