35 A oil pressure problem
M B Deere
01-24-2008 16:30:17
I'm not sure if My 35 A is making enough oil pressure or not. The pop up oil pressure indicator is popping up no problem. but when i hook up a pressure gauge to the pipe plug on the govenor it does not show any pressure is it possible to check it with a gauge or shoule I assume the pressure is good sence the pop up is working. It takes about 10 lbs of finger pressure to push down the pop up at idle.
Rich Duane
01-25-2008 16:35:54
 Re: 35 A oil pressure problem in reply to M B Deere, 01-24-2008 16:30:17
In Field Service Bulletin 58-S it states that oil pressure on tractors prior to serial number 424025 is 18# at 1050 RPM measured at the oil filter cap. I'm not shure that your filter cover has a 1/8 NPT plug in it,but you could get another cover and drill,tap and screw a master gauge in it to check the pressure. I have seen pictures of this setup in books before. There are no other places to measure oil pressure on the early tractors.
Rich Duane
m B Deere
01-26-2008 06:18:42
 Re: 35 A oil pressure problem in reply to Rich Duane, 01-25-2008 16:35:54
does the service bulliten say anything about how many washers should be on the oil pump pressuse relief valve spring?
Rich Duane
01-26-2008 06:47:35
 Re: 35 A oil pressure problem in reply to m B Deere, 01-26-2008 06:18:42
As in any JD imformation they say to add washers as needed. Some of the problem may lie in the fact that the main and rod bearings need to be reshimed to bring the clearances into spec.Early'A's" are getting a little old.
M B Deere
01-25-2008 18:41:38
thanks for the info. sounds good to me. I may drill and tap my cap just so I can check. thanks again.
Big_Roy
01-25-2008 14:15:48
That should have read: "...can't lay my hands...."
Big_Roy
01-25-2008 14:14:08
 Re: 35 A oil pressure problem in reply to machinery-man, 01-24-2008 16:30:17
If I remember correctly the early unstyled tractors didn't even have as much oil pressure as the later ones. I want to say they only had 5-10psi but can lay my hands on my manual at the moment.
LEH
01-25-2008 05:18:45
If you are looking for a pressure reading like a modern day engine, you are not going to find it. I can't tell you exactly what the factory setting was, but I would say it's around 10 to 15 pounds, 20 at the most. As long as your red head indicator comes up & stays up, you have oil pressure, and it's enough to lubricate the engine for the long haul. I've had my '35 for over 30 year and have had no problems. Never even had to adjust the rod bearings. Just keep plenty of clean oil in it. Check U-Tube for my videos of my old friend at work.
Kemper
01-24-2008 16:38:04
I'ts hard to tell with a numbered pressure guage, your A will only have 10 to 15 psi. Try a guage off a 2 cylinder that has the low,med high, and try that i would bet your oil pressure is fine.
M B Deere
01-25-2008 10:37:29
 Re: 35 A oil pressure problem in reply to Kemper, 01-24-2008 16:38:04
the pressure gauge that I used was a working pressure gauge from a 1947 AR with the low, medium, and high. With that gauge screwed into the pipe plug hole on the governor case it shows no oil pressure, but the pop up is working. I have already rebuilt the oil pump, checked all the oil lines for leaks, checked filter head for leaks. I am not sure if I should be satiflied with that or I should start looking at the bearing for leaks.
LEH
01-25-2008 05:33:14
Kemper has a good idea! Never tried it myself!
