How to keep wheels from sticking to axels
greenmisterg
01-24-2008 10:14:48
Anyone have a proven method of keeping splined wheels from sticking on the shafts? Heard of the wax paper ,,was told anti sieze releases ok but you can never get them tight,,,thanks for the replys! greenmisterg
B51
01-24-2008 17:23:03
 Re: How to keep wheels from sticking to axels in reply to greenmisterg, 01-24-2008 10:14:48
All sound like good ideas. What I'm doing is giving my axles and inner hubs a good bath of phosphoric acid after I have them wire wheeled good. Don't plan on painting them. Might not look the best but I don't want to have to go through what I did to get them off again.
johndeereman
01-24-2008 16:46:12
the worse thing ive seen is people drive them on over top of paint you dont realize how thick the paint is till you try to remove the wheel the paint makes the axle bigger around ya see i would just put a light film of n/s on the axle if you decide to move them in youre lifetime they should be ok
Mike Aylward
01-24-2008 15:58:18
Do not fear the never-seize. If you get the hub tightened securely to the axle they will not give trouble as a rule. I"ve used it for years and have yet to have one work loose. Mike
Kemper
01-24-2008 16:20:38
 Re: How to keep wheels from sticking to axels in reply to Mike Aylward, 01-24-2008 15:58:18
I've never had a problem with never-seize on an axle,but i suppose if you didn't get the hub torqued right they would walk on the axle.
Also once you get them broke loose,they won't get that tight for a good while,alot of these wheels haven't been moved on the axle for 50 or more years...
RobMD
01-24-2008 14:49:40
oh man, I used to have a tractor with never seize on it, and the never seize worked- just not in the way you expect! When plowing, my 4020 turned the wheel inwards slowly, but surely.
Use nothing on the wheels, just keep the tractor in the DRY DRY DRY..... and you won't have too much of a problem!
DJD-Man
01-24-2008 10:35:33
Ive used the wax paper for years and has been a great method. The never seize also works good. Keeping the tractor out of elements helps out alot. If on does not have room to shed it at least cover it with something. Stack plywood along the sides or something. Any bit of help keeps it away from problems later. A little of each formula can go along way. Keeping bolts squirted with your favorite juice all the time helps also.
Mike M
01-24-2008 10:28:37
The wax paper was to keep the clamp ring from sticking on the outside taper of the hub and it works good. The splines ? hard to keep any lube on them and make them stay put when working them hard, like plowing.
