4020 Sychro: how to determine which PTO?
wsimpson
01-24-2008 06:19:19
New to tractors. The service manual says that "Tractors equipped with the Sychro-Range transmission are available with single-speed 1000 rpm or dual speed 540-1000 rpm front and rear PTO shafts."
How do I tell which I have?
Thanks...
Texasmark
01-24-2008 07:22:44
 Re: 4020 Sychro: how to determine which PTO? in reply to wsimpson, 01-24-2008 06:19:19
10-4 on the two rear shafts. If yours has a front pto shaft it is easy to see right behind the engine oil pan and below it. I had the front and rears with both shafts on a 4020 but my 4230 (later model 4020) doesn't have the front; has the swappable rears.
Mark
Gerald J.
01-24-2008 09:29:27
 Re: 4020 Sychro: how to determine which PTO? in reply to Texasmark, 01-24-2008 07:22:44
As far as I can tell, ALL 4020 had the front 1000 rpm PTO shaft. His question is whether he has dual or single speed rear PTO. The answer is the second PTO shaft stub stored in its sideways hole above the working PTO. In the 4020, the front shaft is always 1000 rpm, only the rear changes speed. That was different in the 4010 with the flanged PTO stubs. There both shafts run the same speed.
Gerald J.
Texasmark
01-25-2008 10:31:47
 Re: 4020 Sychro: how to determine which PTO? in reply to Gerald J., 01-24-2008 09:29:27
I think you are correct. I remember seeing the 21 spline on the front and I remember the one stowed aft while the 6 was in use. Did get it out and use it once when I didn"t want to run the tractor at full pto rpm while doing some light mowing. I put in the 21 with an adapter to 6, set the throttle to about 1000 rpms and went about my business with my 540 mower.
Been awhile since I had that baby.
Mark
wsimpson
01-24-2008 07:34:15
Thanks guys.
Walt...
Gerald J.
01-24-2008 06:46:31
If its dual speed there are two possible indicators. It likely will have the 540 rpm PTO shaft in place, 6 splines. The for sure indication is that between the PTO shaft pointing to the rear and the upper three point link anchor, there will be the other PTO shaft pointing to the left in its storage spot. And one PTO shaft will be 6 spline, the other will be 21 spline.
I've looked a few dozen 4020 and have yet to see one that is 1000 RPM only.
Gerald J.
