Need a little help on a 630
IBorange in TX
01-22-2008 20:08:35
Thanks for any info that you can give to me. I recently bought a JD 630LP off of a fence row. If I convert the LP over to regular gas, can you tell me what type and model carb I should use??
Thanks
mb
Mike M
01-23-2008 05:55:19
 Re: Need a little help on a 630 in reply to IBorange in TX, 01-22-2008 20:08:35
The last LP I bought end of DEC. was $2.18 a gallon REG. gas is now at $3.02 and all over the place day by day ? even given that LP will use more than gas due to less BTU's I would think LP would be the way to stay.
And the BIG plus is LP can stay in the tank likely forever and not go bad. Can't do that with reg. gas.
2cylinderlp
01-22-2008 20:45:16
DTLX-106 Not sure if it will bolt right up to the LP manifold, but I think it will. Also not sure if the high compression LP pistons will result in your needing to run a higher grade of fuel. What about a fuel tank and sheet metal to cover it if you change it over? If you can find sheet metal then you would also need the steering wheel support casting. Seems like if you had to buy all new LP stuff (tank valves, tank gage, hoses, solenoid valve, and converter, maybe rebuild carb too) that keeping it LP would still be cheaper, simpler, and better in the long run to me. (run better too) JMHO
4020LP
01-22-2008 20:28:21
Finding the parts to convert a 630LP into a gas burner is going to be a lot more difficult than you think it is, I suspect. Why not fix it up and use it as an LP? Unless you're going to work it really hard, it'll do better on LP, and LP is a lot cheaper than gasoline in most places. All the parts you need to fix up an LP tractor are readily available.
steveormary
01-23-2008 02:10:11
 Re: Need a little help on a 630 in reply to 4020LP, 01-22-2008 20:28:21
I think I would want to keep it LP
steveormary
IBorange in TX
01-23-2008 08:00:38
 Re: Need a little help on a 630 in reply to steveormary, 01-23-2008 02:10:11
Okay, you have talked me into leaving the JD on LP. Thanks a lot, you all are great..... .....
HAVE A GOOD ONE..
RobMD
01-23-2008 09:11:14
 CONTACT NICK BARBIERI FOR PARTS in reply to IBorange in TX, 01-23-2008 08:00:38
Hey, i'll give you the phone number for a good guy who sells all parts LP and everything you need to know. Nick Barbieri (516-221-4116) (nick330 AT optonline DOT net) New York.
