JD 4000 steering wheel leaking oil
RJ IN WYO
01-22-2008 17:16:15
I have a jd 4000 and just recently had a new steering control unit installed. tractor used very little plowed snow loaded and fed a little hay. was working great but oover night oil started leaking under the steering wheel by the hand throttle lever. was wondering if this is just a bad seal in a new rebuilt unit or possibly installing wrong at the dealership. also weather turned extrenely cold two days befor it leaked. would like some imformation befor i talk to the shop. im good enough mecanic to be dangerous so any replies would be appreciated rj in wyo
Tx Jim
01-23-2008 04:12:44
 Re: JD 4000 steering wheel leaking oil in reply to BUTCH GA., 01-22-2008 17:16:15
RJ if I were you I'd tell dealer to redo the steering valve. The easy to get to seals under the steering wheel that Larry refered normally won't stop the leak! Jim
LarrySTN
01-22-2008 18:03:01
 Re: JD 4000 steering wheel leaking oil in reply to RJ IN WYO, 01-22-2008 17:16:15
Having rebuilt several of these units, my guess is that the unit was not thoroughly rebuilt. There is a packing that is difficult to replace that likely was not replaced.
There are seals right under the steering wheel that may have been damaged during installation, or improperly installed, those are easy to replace.
