4640 axle duals ?'s
Farm W/Junk
01-22-2008 15:02:03
Hi I recently bought a 4640 and it came with clamp on duals. I would like to put axle duals on it and was wondering if it is possible? Ive seen them equipped before but my axles seem too short and wondered if there was different length axles. If the axles are long enough do deere hubs fit? Or do I need an aftermarket such as M&W or unverferth? I have roughly 6 inched to work with. Does anyone know of a source in Ohio area? Thank you so much. Matt
Dean Barker
01-23-2008 11:20:41
 Re: 4640 axle duals ?'s in reply to Farm W/Junk, 01-22-2008 15:02:03
I installed 18.4 - 38 hub duals on my 4320 with the shortest axles available. I was concerned too about everything fitting and having enough room between the tires, but everything is ok. The dual rims have the standard offset also. 4320's were offered with 4 different length axles; one of mine has the shortest and the other has the longest axles.
MSM
01-22-2008 15:43:33
If you have the short(standard) axles it might be possible but the inner wheels are going to be REAL close to the cab.If you move the inner wheels in,and use a hub mount with stamped steel wheels you may get away with it. Most axle cast center duals use the long axle shafts,about 12" longer per side than what you have.
