2030 Brake trouble
charlesmm
01-22-2008 00:36:53
I'm baffled and confused , one brake was spongey so I replaced the O rings , no difference, replaced the valve under the plug at the top ( Sits in a big plug with a screw driver groove in top). Now both peddles go to the floor . I did a lot of bleeding but no change, Any ideas?
charlesmm
01-22-2008 07:48:08
 Re: 2030 Brake trouble in reply to charlesmm, 01-22-2008 00:36:53
WTW , you may be right as when the brake was tested it seemed to bind up to start with , this may have damaged it.
WTW
01-22-2008 09:23:48
 Re: 2030 Brake trouble in reply to charlesmm, 01-22-2008 07:48:08
The bind you speak of just confirms my suspicion. You will see the damage done to check valve when you remove it from the holder/seat (valve held in holder with wrap around spring). The valve is shaped like a short nail. The top of the head end of it is where it seats against round hole in holder (hole in center of the large slot). This head end will be bent where it will not lay flat over the hole in seat/holder. Just study it you will see what I am trying to explain. Good Luck, DW
WTW
01-22-2008 07:09:48
Sir, This sounds like a common problem I have seen many times. In your case the check valve that is under the large screwdriver slotted plug has been damaged when you installed them. This is very easy to do if not done correctly. When installing them the brake valve spool has to be depressed a small amount to keep check valve stem from contacting spool shoulder/gland. If check valve assembly is installed without correct position of spool the check valve will get bent when tightened down in bottom of valve housing. Once they are damaged they will not seat and pedal/spool will never trap oil to allow pressure to be applied to brakes. Pedal will just settle or go to the bottom when brake pedal pressure is applied. You can replace these check valves without removing the valve assembly from tractor, just remove the plugs above them to gain access and remove them. When installing them hold pedal just off the normal "upper" stop. If resistance is felt reposition pedal a little until valve assembly can be installed without interference with spool. Good Luck, DW
Mike M
01-22-2008 04:23:28
Have you changed to packings on the piston in the axle housing ?
