Clutch
54/60
01-21-2008 21:08:11
I am replaceing the clutch driver and the slideing clutch disk on my 1954 JD 60. I never had one of these apart so my question is there anything behind the pulley i need to clean and lube before putting on the new parts. I pulled the pulley back a little and seen what looked like roller bearings and some kind of arms that pivot. Also is there anything special I need to do when pulling off the pulley and slideing the pulley back on. Also I am installing the flywheel back on the tractor my other question is should I tighten the two bolts that hold the flywheel tight against the crankshaft first or the locknut that keeps the flywheel on the crankshaft, Sorry I am so long winded I just want to make shure I do this all right. Thanks
RobMD
01-22-2008 15:05:51
 Re: Clutch in reply to 54/60, 01-21-2008 21:08:11
The locknut sets your required crankshaft end play of around ten thou. THEN you tighten the two clamp bolts, and TIGHT. TORQUED TIGHT.
Buck eye al
01-22-2008 14:26:01
What ET said plus make sure the three springs that are between the pulley & the outer disk are good. They get weak from rust & can make it disengage poorly as in "wants to keep going".
ET
01-22-2008 04:58:37
WhenI redo a clutch I repack the roller bearing with high tempature grease, clean and never-seeze the contact area of the three operating bolts, remove and clean the toggles, I put a dab of high temp. grease in all the toggle pockets as well as the pockets on the operating sleeve and never-seeze the three pivot pins that hold toggles. Make sure the guide pin and hole it runs in on the operating sleeve are not worn.
