1970 2520 with model 48 loader
SWMO chris
01-21-2008 19:03:45
I have a 2520 with a model 48 loader mounted on it. I would like to remove the loader this summer for field work. I cannot figure out if the loader has stands that it can be placed on when not in use or if it will require an overhead support to hang it on. Any help would be appreciated.
RobMD
01-21-2008 20:00:16
 Re: 1970 2520 with model 48 loader in reply to SWMO chris, 01-21-2008 19:03:45
I made some for my 48 loader, which is on my 2155. Just bolted a piece of square tubing welded to a 3/8 flange on both sides of the loader arms. Then, I took tubing that fits inside the tubing on the loader arms, and made them so they slide in and out with pins to hold them in. These tubings stick out about 1.5 feet from the loader arm, then go straight down with 2 inch channel iron and a 5 inch square base plate. The end result is two "L" shaped support stands that are placed on the loader after picking the arms up hydraulically about 5 inches. Then, you remove the front retaining pin, and back out. (I had to manufacture this retaining pin- this is just a piece of half inch round stock bent in the middle to go around the loader support pipe up front)
I will try to post pics, no guarantees.
msb
01-21-2008 19:25:07
A 48 loader had a pair of legs that were very easy to install and worked great. You unhook the loader and raise the bucket which will lift the loader out of the saddles and then the legs were bolted on. Drop the loader back down a bit and back out of it.Easiest Deere loader to mount of all. Unfortunately Dunham won an patent infringment suit against Deere back in the 70s and Deere had to stop building the 48 loader. Wouldn't be hard to make some, if you can't find any to buy.
