3020 Roll-O-Matic needed
Roger in Iowa
01-21-2008 13:13:15
Please see the ad to the left.
I broke the left front wheel off at the lower left pivot shaft of mine. I was blading snow so the pheasants could get to come corn left in the fields and hit a ditch hidden by the snow.
I am in Ottumwa Iowa
Roger in Iowa
Roger in Iowa
01-22-2008 12:48:00
 Re: 3020 Roll-O-Matic needed in reply to Roger in Iowa, 01-21-2008 13:13:15
I found a unit less hubs. I believe I can install my arms/spindles with hubs as there appears to be no damage to mine. The unit I found does not have hubs and parts are somewhat rusty. Had to pay $50. Was not found thru this site.
Thanks for all your input.
Roger in Iowa
TIMAR
01-22-2008 09:26:25
LOOK UP TH PAGE. Randy G has one he wants to sell.
rcola
01-21-2008 21:08:40
 Re: 3020 Roll-O-Matic needed in reply to wijim, 01-21-2008 13:13:15
I have a WFE 3010 and want to put the NFE roll-o-matic on. Will the wheels and tires fit from the WFE, or is the dish or wheel style different?
Roger in Iowa
01-21-2008 19:22:32
Gentlemen:
Thanks for all the responses. I believe I have found one here near Ottumwa.
Appreciate your help and input.
Regards,
Roger in Iowa
bc in mo
01-21-2008 15:52:37
I have a 3020 rollamatic front end also. Not too far from ottumwa.
Roger in Iowa
01-22-2008 17:55:55
 bc in mo or freddie in reply to bc in mo, 01-21-2008 15:52:37
The rol-o-matic I found has the 4 bolt axle caps but is not the heavy duty one.
The heavy duty one has four bolts but in a rectangle and one side is 3 inches center to center.
Do you have one and where? E-mail is open.
Roger in Iowa
Ottumwa
freddy
01-21-2008 15:08:13
is it similar to the 4020's I have one cheap
4020LP
01-21-2008 18:29:27
 Re: 3020 Roll-O-Matic needed in reply to freddy, 01-21-2008 15:08:13
With the exception of the "small" Roll-O-Matic used on 1010 and 2010 tractors, Roll-O-Matics are interchangeable from a 50 to a 4320. There's a number of different versions, different spindles, hubs, etc, depending on whether it's a light, medium, or heavy-duty unit,but all will physically fit. The one used on 4020's is the best and strongest model made. There was a comprehensive article on them in the January-February 2004 issue of Two-Cylinder.
littleschnebs
01-21-2008 14:57:48
If it is the same one as a 3010, Justin Meyer has one in Minnesota his number is 651-380-3892 HOPE THIS HELPS!!!
j meyer
01-21-2008 16:13:58
 Re: 3020 Roll-O-Matic needed in reply to littleschnebs, 01-21-2008 14:57:48
Well, thanks for the plug on that, I appreciate it. Mine is still available, ready to put on a tractor
