4440 feels like clutch is slipping
4440 owner
01-21-2008 04:48:48
when plowing yesterday it started to feel like the clutch was slipping on my 4440. It was in a middle of a strip not just starting out and i had plowed from 7-2 that day with no problem. It also has a cermic clutch which was installed 2 years ago. Let me know what u think and i did check my hydraulic fluid, and i am going to try changing the filter today. let me know what you think.
Tx Jim
01-23-2008 03:53:21
 Re: 4440 feels like clutch is slipping in reply to Kemper, 01-21-2008 04:48:48
Mark I should have added "except powershift equiped tractors" Jim
Tx Jim
01-23-2008 03:50:48
 Re: 4440 feels like clutch is slipping in reply to Maark, 01-21-2008 04:48:48
Mark all Waterloo tractors manufactured after '72 had Permaclutches(wet). This includes your 4230. Jim
Texasmark
01-22-2008 15:31:32
 Re: 4440 feels like clutch is slipping in reply to 4440 owner, 01-21-2008 04:48:48
Okayeeeee ee. For all you guys that are apparently in the know..... how does one know if his Deere has a wet or dry clutch? Case in point, "74 4230.
Thanks,
Mark
4440owner
01-21-2008 17:55:25
k thanks and it is a ceramic tiped clutch i tried it out today after changing the filter i am going to check the valve pressure for the main clutch and go from there and possibly maybe a split it in the spring.
powertech84
01-21-2008 17:01:19
not a lot of info to go on, but if its a powershift, and it slips in all gears, its probly the dampner. if its a quad, and it slips in 1 and 2, its the perma clutch, wet clutch. 1 but not two, or vice versa
Heat Houser
01-21-2008 16:16:23
It could be the main clutch on the flywheel or one of the "hi-low" clutches in the transmission. (Assumes that you have a quad range transmission)
The main clutch is applied by putting pressure to the clutch piston which pushes on the fingers and applies the clutch. Take pressure away to release. This same pressure is used to apply the cluch packs in the hi-low. If it is the hi-low, one side should hold and lug the engine. If it slips in both, it is likely the main clutch.
If the transmission oil is saturated with water, the facings of the main clutch can de-bond due to rust. You will find fiberous stuff in your filter. (ask me how I know this)
It could be low clutch apply pressure. Does the transmission light flash?
4020LP
01-21-2008 09:19:19
A ceramic clutch? Every 4440 with a transmission other than a Power Shift had a Perma-Clutch multiple-disk wet clutch.
Texasmark
01-21-2008 07:46:18
Clutch is dry isn't it? Never had a 4440, have a 4230. So why would you be checking your hyd fluid?
I saw a buyer test a clutch one day. He put the tractor in a high gear and pushed in on the brakes, revved it up and let the clutch out slowly. If the engine loaded up the clutch was good.
HTH
Mark
Bob
01-21-2008 07:12:35
A CERAMIC clutch in a 4440???
