50 power steering actuating sleeve - Richard Duane
Jason Z in MO
01-20-2008 20:15:37
I know Richard can help in this area, others also...
I have a 50 with worn steering shaft splines both on the shaft and actuating sleeve. I have a very good used actuating sleeve I know came from a 520 but I don't know if it was an early AF1938R
which was also used on the 50 or the later sleeve AR20168R.
How can the sleeve be identified?
Richard, Will you be at the Gathering of the Green? I will need a splined steering stub shaft for sure. If I don't have a AF1938R I will probably need that part as well. Thank you for making these parts available!
Jason
Rich Duane
01-21-2008 16:53:46
 Re: 50 power steering actuating sleeve - Richard Duane in reply to Jason Z in MO, 01-20-2008 20:15:37
To identify the diferent control sleaves,the first style(Af 1938 R) on the side with two holes the front hole is threaded for the adjusting screw and the pins on the other side are small. On the(AR 20168 R and AR 20655) none of the holes are threaded and the pins are larger. As for the spline repair it will not work on the "50" or the "520" because the steering shaft on these tractors are solid. I do make new shafts with either the taper or the steering wheel spline for $175.00. If I can answer any other questions feel free to call 410-643-2899 Rich Duane P.S. If I can bring any special items to the Gathering let me know.
jdhbag
01-21-2008 11:33:40
Rich tells me that he will be at GOG, he is conducting a seminar.
Jason Z in MO
01-21-2008 11:39:01
 Re: 50 power steering actuating sleeve - Richard Duane in reply to jdhbag, 01-21-2008 11:33:40
Thanks! I know he was there in years past but should have looked at this years agenda.
Mike M
01-21-2008 06:10:20
DO YOU HAVE A COPY OF THE JD MANUAL #SM2050 I THINK IS THE NUMBER. (dang caps locks) It is clearly showed in there and I would not even think of working on one of those systems without that manual ! The early design uses one adjusting screw with a slotted head and i think that sleeve is all one piece. Where the later ones use 2 solid pins and the front most end has threads and an adjustable bushing in it.And is made in 2 pieces or more ?
Jason Z in MO
01-21-2008 11:40:33
 Re: 50 power steering actuating sleeve - Richard Duane in reply to Mike M, 01-21-2008 06:10:20
Mike,
You're right! I just didn't look closely enough at the manual, I do have SM-2050.
The spare actuating sleeve I have is the later design with two pins and no set screw. This is getting expensive FAST!
Mike M
01-21-2008 11:58:11
 Re: 50 power steering actuating sleeve - Richard Duane in reply to Jason Z in MO, 01-21-2008 11:40:33
VERY GLAD to hear you have that book as it is a wealth of info ! unless they downsized it from my older copy ? it has theroy of operations and oil flow charts in color too if I remember right .
If you have the whole valve housing and assy. you could swap it all out unless you have the old style pump with a relief valve in it. Or I bet someone would trade an old stlye for a newer one as the newer style gave more troubles with cracked corners and splits by the keyway.
Jason Z in MO
01-21-2008 16:33:53
 Re: 50 power steering actuating sleeve - Richard Duane in reply to Mike M, 01-21-2008 11:58:11
Mike,
I had thought about swapping the whole housing like you suggested. Not sure I have all the parts needed. The 50 does have the original pump with the relief valve on the right side so that would be an issue. I didn't know about the problems the newer pumps had; good to know.
Honestly, I'm a bit of a purist and would prefer it keep it original, call me crazy I know... Not that I'm a member of the "correct police" but prefer to keep MY tractors the way they came. Besides, I have a 520 that I know will need some of these steering parts. It has started giving me problems with locking up and not able to turn left. Now that I know what I have, I checked and parts will work on the 520.
I have a copy of the manual so I don't get the pleasure of seeing the color pages. I also have SM-2016 which is the manual specifically for the early version system. I know it may not seem like it with some of the questions I ask but I do like to surround myself with books and manuals!
The power steering on this 50 works really well but I would like to remove the play between the shaft to actuating sleeve. Guess I could cut a little off the steering shaft and drive it a little deeper and drill a new hole. That should last a little while. The unit does need to come apart. The lower seal is leaking. Also, the system has red ATF fluid in it. Not sure how that affects things...
Thanks as always for your help! You going to GOG?
Jason
4020LP
01-21-2008 18:39:15
 Re: 50 power steering actuating sleeve - Richard Duane in reply to Jason Z in MO, 01-21-2008 16:33:53
I know it's pricey, but do yourself and your tractor a favor, and drain that red ATF and replace it with the JD Power Steering oil. It's much cheaper in the long run, as it will prevent a lot of expensive problems. Some people say it doesn't matter, but I've seen too many "problem children" PS systems running ATF or hydraulic fluid get healed just by draining that junk out and putting in the proper oil.
Jason Z in MO
01-21-2008 19:22:24
 Re: 50 power steering actuating sleeve - Richard Duane in reply to 4020LP, 01-21-2008 18:39:15
4020LP,
yep, it will get the JD oil when I replace the lower seal.
Mike, this isn't just gas for work... THIS IS A JOHN DEERE TRACTOR! LOL!!!!
Jason Z in MO
01-21-2008 19:06:19
4020LP,
Mike M
01-21-2008 18:12:42
I can't even afford gas to go to work.
I may of confused you ? The late pumps are not the problem area the late design "improved" actuating sleeve is.
And yes if you have the early system and it does work no reason to change everything over.
Wonder if some of these miracle expoxy's could be put in those worn splines after being super cleaned and a relase agent applied to the shaft ? I think loctite made a kit for worn threads to do just that so it may work on splines ? or maybe they make one for splines ?
A good tight fitting roll pin helps for awhile too. Be sure to safety wire it in place so as it wears and could loosen it doesn't fall out going down the road.
